Flycutting Tools
Old 01-04-2008, 02:13 PM
  #41
johnLs1camaro's Avatar
if anyone wants a set i have a brand new set
PNT-218 .. 2 1/8'' Intake valve cutter
PNT-134 .. 1 3/4'' Exhuast valve cutter
NP - 516 .. 5/16'' PILOT
ill sell shipped for 140 i paid 210
Old 01-04-2008, 03:40 PM
  #42
Bill Bowling's Avatar
I need a set for Dart 205's 2.02" / 1.60" 8mm.
Bill
Old 01-04-2008, 04:23 PM
  #43
405HP_Z06's Avatar
Bill
I've got 2.05 and 1.60's
Old 05-02-2008, 11:48 AM
  #44
405HP_Z06's Avatar
TTT, for those that may need to flycutters for an upcoming head swap.
Old 05-02-2008, 12:38 PM
  #45
PRO AUTO's Avatar
Aaron, how do you get in touch with this fellow? Do you have his number? Thanks.
Old 05-02-2008, 12:44 PM
  #46
405HP_Z06's Avatar
1-877-ETSUPPLY (387-8775)
Old 05-02-2008, 12:49 PM
  #47
PRO AUTO's Avatar
Thanks Aaron.
Old 05-02-2008, 01:34 PM
  #48
studderin's Avatar
im looking for a used set
Old 05-02-2008, 01:41 PM
  #49
Fratsit's Avatar
For what size valves?
Old 05-02-2008, 03:08 PM
  #50
GuitsBoy's Avatar
Those tools look pretty sweet, still a little pricey though. I tried doing something similar myself but the steel I had on hand was simply not hard enough.
I eventually decided to use replaceable adhesive sandpaper disks, which work great. Heres a couple of pics of the flycutting tools I made using only a lathe, and about 5 bucks worth of hardware. Ive used these on quite a few motors with great results. The only pain in the *** is cutting out the sandpaper, and then peeling it back off the disk. It needs a new piece of sand paper for every cut, which can be a little time consuming, but you cant beat the price!
Old 05-02-2008, 03:20 PM
  #51
405HP_Z06's Avatar
Great tool you made there and you can't beat the price. I agree the Lindy tools are a little expensive for one time use, but they are competitively priced when compared to other products like it on the market. The huge advantage to the Lindy Tools don't require any modification to the head and don't harm the head in any way. They also provide a nice radiused cut in the piston instead of a sharp angle that is prone to cracking.
Old 05-02-2008, 04:03 PM
  #52
GuitsBoy's Avatar
Thanks man. That is great that they do not require modification to the head. I probably could have squeezed mine in there if I spend a little more time on teh lathe trimming them down, but I happened to have a junk head that I had used to practice my porting skills, so I just popped my valve seats out.
One concern about the Liny tools radius is that you need to cut an even larger diameter flycut in the piston to gain the same valve clearance than you would have to cut without the radius. This could translate to slightly less compression. Probably on the order of .5 to 1 cc for both valves combined, but its something to consider. Granted that it does stand to reason it would be stronger radiused.
Old 05-02-2008, 06:05 PM
  #53
405HP_Z06's Avatar
....One concern about the Liny tools radius is that you need to cut an even larger diameter flycut in the piston to gain the same valve clearance than you would have to cut without the radius. This could translate to slightly less compression. Probably on the order of .5 to 1 cc for both valves combined, but its something to consider. Granted that it does stand to reason it would be stronger radiused.
Not a concern because you need to maintain .050" radial valve clearance in the flycut. The .5 - 1cc for the radius is overly optimistic, probably in the neighborhood of .1cc per valve.
Old 05-04-2008, 08:33 AM
  #54
TXZ0603's Avatar
For those that have done this, I will be using a set of 59cc heads with a .040 cometic gasket. The cam I will be using is a ms4. IIRC the lift is 640/609?? <---might be off a bit. How deep will I have to FC if using the 7.4 pushrods and 1.7 HS rockers??
Old 05-04-2008, 02:48 PM
  #55
What is the rest of the cam specs?
Bill
Old 05-04-2008, 02:50 PM
  #56
Those do look pretty good. And like you said you can not beat the price. It just takes time.
Bill
Old 05-04-2008, 06:30 PM
  #57
TXZ0603's Avatar
Bill
this is what i got off their site:
Magic Stick V.4 239/242, .649"/.609"
Old 06-19-2008, 03:55 PM
  #58
LS1C5Vette's Avatar
Would I only have to flycut the intake valve side if I wanted to run a 59 or 60cc chamber (on some tsp stg 2.5 5.3l heads) and a .040 gasket with my 233/239 cam??
Old 06-19-2008, 04:09 PM
  #59
2gofast's Avatar
You are going to have to measure. It is that simple. Do not go by other's experience. Measure and, if needed, then get the tool(s) and cut.
I was told that the exhaust would not need to be cut and that I would only have to cut the intake. I have a G5X3 cam with LS6/2 head 60cc. Well, I measured and found I needed to cut both. I measured an initial PTV of .007 intake and 0.054 exhaust. So, if I took the advice, my exhaust PTV would be way to close and subject to hitting the piston. I have a 6spd and that represents even more possibility of hitting.
Do it right and measure - you will sleep better knowing what you have and that it is done right.
Old 06-19-2008, 04:50 PM
  #60
LS1C5Vette's Avatar
I know I will need to flycut thats why I asked that, what exact tool is needed to measure? Can I just use clay and turn the motor over by hand and measure the dents?
Quick Reply: Flycutting Tools
