Valves to big??
Old Dec 20, 2007 | 12:45 AM
4psi's Avatar
Default Valves to big??
I have a set of PRC Texas-Speed 5.3 litter heads. My heads are stage 3, which have Manley Valves 2.08 / 1.60. The stage 2.5 heads come with the stainless Steel 2.04"/1.575" Valves.
Cam is Thunder Racing T-rex
Stock shortblock with arp rob bolts and all that stuff.
The PTV clearance is no good.
Are my valves to big for a 347 Ci engine?
My options are get new pistons with enough valve relief, or sell my heads and get a set of the stage 2.5.
Old Dec 20, 2007 | 12:53 AM
PREDATOR-Z's Avatar
Even the 2.5s will not clear a T-Rex.
you need to flycut. and yes your 2.08 valves are counterproductive for a 346 (valve shrouding).
To clear T-Rex without flycuting you need 243 (LS2/LS6) casting unmilled stage 1 (stock valves) with stock gasket. Or LS1 casting.
Any stock castings with bigger than stock valves will need to flycut.
Old Dec 20, 2007 | 01:04 AM
4psi's Avatar
My machine shop told me that with the 2.08 / 1.60 valves Flycutting is not an option, they would have to take way to much off the pistons. Would the benefits or using a 2.5 be worth flycutting the pistons or should I just go with a stock size valve?
What will the difference in performance be between stock size valves and 2.04"/1.575" Valves?
Old Dec 20, 2007 | 01:17 AM
Die Grinder's Avatar
Ls1 2.08/3.905 = .532% of bore dia. (o/s valve)
L92 2.16/4.060 = .532% of bore dia. (stock valve)
Shrouding not always bad.
Old Dec 20, 2007 | 01:30 AM
4psi's Avatar
Are you saying I should just keep what I have and and go with a piston that allows enough valve relief?
Old Dec 20, 2007 | 05:37 AM
PREDATOR-Z's Avatar
On stock cubes, if you can afford it, that would be nice. That involves a whole bottom rebuild, so getting a set of ported 243's stage1 for less than $1K is much cheaper.
Old Dec 21, 2007 | 01:21 AM
4psi's Avatar
On a stock shortblock with the t-rex cam what size valves will make the most power and be the best for my setup? If I don't buy pistons with valve relief what will benefit me the most even If I have to flycut the stock pistons? Sorry for the newbie questions guys I tried searching for my answer but came up short. Also how much can I take off the pistons (flycutting) with out having to worry about going to deep.
Thanks for any advice you can give me!!
Old Dec 21, 2007 | 06:36 AM
PREDATOR-Z's Avatar
You can go .100 in depth but .080 intake & exhaust should be enough (2cc)
Old Dec 21, 2007 | 01:17 PM
4psi's Avatar
Ok I found out that my valves are actually 2.02/1.60.
My cam is 242/248 .610/.615 110+2
My machine shop told me that it needs to be cut .100 and they will not do it for me. There is a guy that I found local that can. My question now is will the pistons be to weak for nitrous?
Old Dec 21, 2007 | 04:21 PM
JPH's Avatar
JPH
the pistons .250 thick. only cut what you need. degree, check ptv, then determine how much to cut.
