LSA ????s
Old Dec 22, 2007 | 11:22 PM
02c6ss's Avatar
Default LSA ????s
Im gonna order a TSP ms3 cam after Christmas and was torn between what lsa to go with. The cam will be going in a 2001 A4 SS daily driver with longtubes and 3600-3800 stall. It is offered in 112,113,114. I was thinking about going with the 114 for streetable. Will I see a big power loss?? There will be nitrous on this engine if it matters...
Old Dec 23, 2007 | 12:37 AM
socal's Avatar
stay w 112 for the spray but i would go 114 or more w the a4
Old Dec 23, 2007 | 02:46 AM
SOMbitch's Avatar
Lower LSA will bring the powerband in earlier and have a choppier idle and be a little harder to tune. Why not compromise a bit and go 113. Many do.
Old Dec 23, 2007 | 09:39 AM
02c6ss's Avatar
I was thinking about the 113
Old Dec 26, 2007 | 05:45 PM
Prey4Me's Avatar
Sorry, but I was just reading this thread and came to your name and just started laughing in the middle of work . Sorry continue thread.
Old Dec 26, 2007 | 09:48 PM
DONAIMIAN's Avatar
IMHO if you have to open the LSA on a specific cam just for its prolly too big for you.
Old Dec 27, 2007 | 09:19 AM
miller456's Avatar
What is the reason for going with ms3? Why not go with new ms4?
Old Dec 27, 2007 | 09:22 AM
bjamick's Avatar
THe MS3 is a lil more forgiving on the valvetrain. The MS4's intake side @ a .649 lift, it just beats the hell outta the valvetrain.
Old Dec 27, 2007 | 09:59 AM
miller456's Avatar
Thats y u do a valvetrain upgrade with your cam swap. The ms4 has much better low end tq compared to ms3. I called texas speed said ptv clearance was ok with stock heads and no flycutting. Get the prc dual spring kit with titanium retainers, ls7 lifters, ls6 oil pump, ls2 timing chain or w/e set up ur goin with and they explained everything would be ok. Just needs diff gearing and beings i had a 98 the pcm was a little harder to tune.
Old Dec 27, 2007 | 10:46 AM
LS1SpeedAddict's Avatar
I would go 113 for the same reasons I did, a 113 will still sound choppy and its still good for nitrous. Ideally you want the 114 for nitrous but if a cam doesn't sound a little choppy then its no fun.
Old Dec 27, 2007 | 11:31 AM
c5_ls1_6spd's Avatar
I have an MS3 on a 114LSA and it chops HARD.
Old Dec 29, 2007 | 12:18 PM
I'm sure it does, 114s don't sound bad at all but I had a 114LSA before and I wanted something more radical this time.
