4" Eagle Crank????////
I had a motor build about 2 months back. We couldnt get the car to runn right and turned out to be the reluctor wheel. I have pulled the motor but thinking about stroking it. IM looking to get a 4" eagle crank. Will it work with my set up?
3.905 bore 01 BLOCK
6.125" Eagle Rods
Lunati 3.903" pistons
3.905 bore 01 BLOCK
6.125" Eagle Rods
We offer the full line of Wiseco Pistons. Depending on your compression goals there are several pistons to choose from. These pistons retail for $559. We can also add on a new Wiseco Moly ring pack for $159.99.
If you are looking for a 4" crank we also offer forged stroker cranks from K1 Technologies for $849.99!!
If you purchase the crank and pistons from us I am sure I can cut you a good deal on balancing your new rotating assembly. We can even assemble your piston and rod assemblies for you.
I am also going to be posting some great pricing for the new year celebrating our 40th Anniversary! If you need your short block assembled let me know and I can see what we can do for you.
-Leo
-Leo
