Good pistons vs Better pistons
Can you see a noticeable whp difference by just swapping "good" pistons for a "better" pistons with same compression or even less compression than the "good" pistons on a N?A application?
This is just a general question, not necessary LSX engine related. I'm just want to get a second opinion on this matter.
"good" old design
"better" new design
"good" old design
"better" new design
Well it would have to be same "type" of pistons. Like flat-tops Vs flat-tops.
Otherwise yeah, piston design can have an effect on output depending on application used (like head chamber design, piston deck position, piston pin position, rod length etc....)
Moderator
"good" old design
"better" new design
"good" old design
"better" new design
How much of a difference percentage wise? 10%? The good pistons are custom wiseco and the better pistons are custom JE. This is just a back and forth argument in an atv forum between 2 engine builders.
