after head/cam install
Old Jun 30, 2003 | 01:42 AM
Z28_HESS's Avatar
Default after head/cam install
I'm about to get a head/cam package soon and I know I will need a tune after I have it installed with my A4. But the question is after the install, will the car run like $hit or does it just not put out all that it could? So could drive her around for a while till I got the tune or do I need to get a dyno tune right after the H/C install?
I will be installing:
stage II 5.3l heads
224/224 112LSA
Thanks,
Warren
Old Jun 30, 2003 | 07:31 AM
Z28_HESS's Avatar
Default Re: after head/cam install
hey, someone now please.
Thanks,
Warren
TTT
Old Jun 30, 2003 | 08:19 AM
JPR's Avatar
JPR
Warren,
It will run decent, but I would have used a 114 for an A4 personally. There's definatly going to be a couple types of idle symptoms but for the most part, just get it edited asap because the SES is gonna drive you nuts from the random misfire codes setting off and most likely some stalling issues.
Joe.
Old Jun 30, 2003 | 10:18 AM
Cal's Avatar
Cal
Running like $hit or not is a bit subjective, but you might want to be ready to slam it into neutral each time you're about to stop so it won't kill.
