recommendations with 228R cam??
Old Dec 30, 2007 | 02:15 PM
rubenlee21's Avatar
Default recommendations with 228R cam??
sup fellas i wanna do a cam swap with my 2002 WS6 m6. Will be gettin pacesetter longtubes shoryly. so far my mods are corsa cat back , and slp lid. Any guys famailar with this cam? TSP has a pretty good package deal for 700 bucks with the double springs. Do you guys recomment a aftermarket timing chain? oh ya car has 59,000 miles.
Old Dec 30, 2007 | 02:31 PM
Tainted's Avatar
get an ls2 timing chain as well as the package. the 228r is a great cam for a medium sized cam and have a really strong midrange
Old Dec 30, 2007 | 03:04 PM
rubenlee21's Avatar
sounds good man. thanks
Old Dec 30, 2007 | 03:11 PM
Jays00ss's Avatar
Might want to get some hardened pushrods as well, and a Ls6 ported and shimmed oil pump.
Old Dec 30, 2007 | 03:14 PM
Tainted's Avatar
I think the package comes with pushrods. he can order the ls6 oil pump if it doesnt come with that already.
p.s. dont forget! get the 112lsa
Old Dec 30, 2007 | 04:24 PM
Phil'sC5vette's Avatar
see sig
Old Dec 30, 2007 | 05:09 PM
Eatinstang4life's Avatar
Dont really need a new oil pump just shim the bypass spring and clean up the machine defects inside with a dremel.
Old Dec 30, 2007 | 05:28 PM
deadmanTA's Avatar
Go for it!
Old Dec 31, 2007 | 01:32 AM
DarkJuggalo's Avatar
do the pistons need to be fly cut for that cam? i want a cam that doesnt need to alter the pistons
Old Dec 31, 2007 | 01:49 AM
Tainted's Avatar
nope clears stock heads n pistons
Old Dec 31, 2007 | 02:08 AM
Third Gear's Avatar
If you have a little extra cash get the JWIS/Katech timing chain... it's THE best single chain you can buy. I'm running it, it's a quality piece.
Old Dec 31, 2007 | 05:25 AM
my AFR heads are milled to 62CC and no need to fly cut.
I hear alot of people going to the LS2 timing chain. Its cheaper and good quality
Old Dec 31, 2007 | 12:09 PM
rubenlee21's Avatar
sounds like its a pretty good cam. do i really need to mess with the oil pump though?
Old Dec 31, 2007 | 04:16 PM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
the ported oil pump is available off our site for $124.99. If your wanting to replace the pump while your at it...
Jason
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Dec 31, 2007 | 06:01 PM
deadmanTA's Avatar
It's a nice little upgrade for good measure and it would be a pain in the *** to do all that work again just to put one in, but its not necessary.
Old Dec 31, 2007 | 09:00 PM
my01camaroz28's Avatar
That cam is an all around great cam. Since it has high lift and XER lobes it produces lots of power. I had this cam on a stock set of 243 heads with dual exhaust and some tuning. Put down 422, 408 to the wheels. I plan to get either that or a 230 cam for my next car. I can provide you with a dyno sheet on that cam if you like.
Old Dec 31, 2007 | 09:31 PM
jsteele90's Avatar
just go with the ms4 and call it a day
Old Dec 31, 2007 | 09:41 PM
EndlessSummer85's Avatar
m6 or a4??? That cam is pretty stout, and is well proven. I would def get a new oil pump, and an ls2 timing chain, cheap insurance.
Old Jan 1, 2008 | 08:47 AM
Giddswat's Avatar
Good cam choice!
