What are u doing o keep lifters from falling??!!
Old Dec 30, 2007 | 04:43 PM
Eatinstang4life's Avatar
Default What are u doing o keep lifters from falling??!!
Will I know you can buy the tools from thunder racing to slide in, or use magnets. Instead of buying the thunder racing tool can you just slide in a metal rod or something to hold the lifters up?
Old Dec 30, 2007 | 05:36 PM
Fratsit's Avatar
Yes you can. I used wood dowls. There has been alot of discussion about this over the years. A search could turn up alot of info. If I remember correctly I used 5/16". You can also use metal rods, just shave them down on one side.
R/
Frat
Old Dec 30, 2007 | 05:40 PM
Fratsit's Avatar
Here is some good info
https://ls1tech.com/forums/showthrea...ighlight=dowel
I typed the word "dowel".
R/
Frat
Old Dec 30, 2007 | 06:59 PM
Thanks man.
Old Dec 30, 2007 | 07:08 PM
RGKSR's Avatar
Default Wooden Dowels
I used dowels a couple of times. Be gentle and you won't break one.
Bob K.
Old Dec 30, 2007 | 07:12 PM
Phoenix 5.7's Avatar
i used pen magnets and clothespins and it worked great
Old Dec 30, 2007 | 08:01 PM
I think I will do the dowels a try. Thanks guys
Old Dec 30, 2007 | 08:14 PM
Fratsit's Avatar
Your welcome. Best of luck on the install.
R/
Frat
Old Dec 30, 2007 | 08:16 PM
Randy WS6's Avatar
I use the dows , works grate
Old Dec 30, 2007 | 10:23 PM
johnster's Avatar
5/16 22 inches long
Old Dec 30, 2007 | 11:08 PM
99ssleeper's Avatar
me too, except i had small round magnets affixed to the end of new pencils...worked like a charm. the slickest part about it is the clothes pins, they fit from the edge of the head to the valvespring so well..lol.
Old Dec 30, 2007 | 11:48 PM
who needs harland sharps? these are the ultimate in lightweight. and the pushrods are adjustable!
Old Dec 31, 2007 | 12:18 AM
99ssleeper's Avatar
taste the rainbow.
Old Dec 31, 2007 | 01:40 AM
james562's Avatar
DAMN so thats what there using for the new LS9, gotta love the fisher price engineering!!!
Old Dec 31, 2007 | 08:24 AM
98Camarod's Avatar
Damn, those pen magnets arent cheap, I'd be all over the dowels if I had to do it again. I just pulled mine out, I had my heads off.
Old Dec 31, 2007 | 09:05 AM
Weezzer's Avatar
Two wooden dowels from Wally World = $1.30
Old Dec 31, 2007 | 09:24 AM
CarnivorWS.6-01's Avatar
I just finished mine about 4 days ago. Use the 5/16 metal rods at about $3.00 each. I cut mine to about 22" and the passenger side I ground off about 5/32 the lenghth of the rod the both slipped right in. Oil them for sure. Do not risk wood in your engine. Pen magnets at $5.00 each is not cheap and I have heard of more than one issue with the magnet getting stuck or coming off. I also did TDC for the springs as well as pressurized the cylandar. No such thing as overkill when it comes to safty.
Old Dec 31, 2007 | 12:29 PM
makWS6's Avatar
I was the lucky one whom had the magnet tip get cought on the lifter and pop off! Talk about a "O ****!" feeling. Luckly at the time I worked for a Medical Engineering Company and took a Spinal Implanting tool to get it off the top of the lifter. I'd go dowl!
Old Dec 31, 2007 | 01:11 PM
rocksws6's Avatar
Use the steel dowels. I wouldn't use wood. Seems like to me the wood would leave debris in the motor. The passenger side needs a little bit shaved or ground off. The ground part will go up and towards the middle of the motor.
Old Dec 31, 2007 | 02:33 PM
98Camarod's Avatar
You don't have to tell me that. I had a two collapsed lifters, the heads had to come off.
