G5X3 or MS3
Old Dec 30, 2007 | 11:46 PM
mchdg86's Avatar
Default G5X3 or MS3
I have a set of TSP 5.3 heads with a .04 thick head gasket and am wondering if either of these two cams will clear without fly cutting.
Old Dec 31, 2007 | 12:18 AM
02TransAm/Batmobile's Avatar
You might need to pick a camshaft with a wider LSA. Given that, I would opt for the G5X3, Great performer and high peak numbers. The MS3 is the same but lacks in DCR and SCR so under the curve numbers will be lower.
Old Dec 31, 2007 | 01:00 AM
TXZ28LS1's Avatar
i know lots of guys are running the 5.3/MS3 setup!! but ive been wanting to see cars with those cams race.
Old Dec 31, 2007 | 01:04 AM
mchdg86's Avatar
I know the MS3 and TSP 5.3 combo is very popular, but I think they are all running stock thickness head gaskets and I have a .04 gasket. IIRC the stock gasket is .053.
Old Dec 31, 2007 | 01:22 AM
PREDATOR-Z's Avatar
Depends what you mean by "clear". My advice is call both sponsors, ask for the exact margins on both intake and exhaust.
Pick the ones you feel comfortable with.
Old Dec 31, 2007 | 02:58 PM
01Z0H6's Avatar
I say the G5X3,but then again, i'm partial to mine.
Call LGM..
Old Dec 31, 2007 | 07:52 PM
purdueranger's Avatar
call both places. at LG ask for Louis or Anthony.
Old Dec 31, 2007 | 09:56 PM
mchdg86's Avatar
Call LGM..
Do you have any track times with your current set up?
Old Jan 1, 2008 | 02:05 AM
aDaM Ws6's Avatar
g5x3 !!
Old Jan 1, 2008 | 07:46 AM
1badA3Z's Avatar
Both cams are good.I had the ms3 in mine,and loved it!
Old Jan 1, 2008 | 12:24 PM
mchdg86's Avatar
If neither will fit with out PTV problems how much of a difference would it be from an X3 to an X2? I know the specs on both, Im just talking about overall performnce. IIRC the X3 is a 234/242 and X2 is 232/240.
Old Jan 1, 2008 | 02:00 PM
Russ K's Avatar
I just ordered the LG G5X3 114 LSA camshaft. I have LPE ported LS6 heads milled to 61cc with .052 MLS gaskets. The valves are 2.02/1.55. I measured the valve drop at TDC, and there is .180 on the intake & .205 on the exhaust. There will be ~.057 PTV on the intake, and more than enough PTV on the exhaust because the cam is advanced ~4*.
Russ Kemp
Old Jan 2, 2008 | 07:21 AM
PREDATOR-Z's Avatar
Russ Kemp
PTV should be measured 10* BTDC on intake and 10* ATDC on exhaust. That is where contact will occur.
.057 at TDC can be less 10* before that, be very careful and measure correctly with a dial and wheel.
Old Jan 2, 2008 | 09:43 AM
N4cer's Avatar
We've always measured by turning the engine a rotation, so we don't have to worry about 10* before or 10* above, yadda yadda. A full rotation covers it all.
Old Sep 19, 2009 | 07:47 PM
Phil'sC5vette's Avatar
Russ,
Hows that cam working out ?
Russ Kemp
Old Sep 20, 2009 | 04:54 AM
PREDATOR-Z's Avatar
So you measure PTV at BDC as well? or your measurement is if it turns over it "clears".
We are talking actual measurements using a degree wheel and dial
Old Sep 20, 2009 | 11:53 AM
fatmat80's Avatar
Thumbs up
ms3 all the way..
Old Sep 20, 2009 | 12:01 PM
NAAllTheWay's Avatar
dont rule out that you could get new gaskets, just a thought, i just wouldnt let my gaskets effect my cam choice, more my cam choice effect my gaskets
Old Sep 20, 2009 | 12:03 PM
jw, why pick a camshaft with a wider lsa?
Old Sep 20, 2009 | 03:44 PM
blue99fbody's Avatar
ms3 i love mine
