lifter question
Old Dec 31, 2007 | 03:24 PM
408Maro's Avatar
Default lifter question
hey guys might sound dumb but whens the right time to upgrade your lifterson our ls1's? is it neccesary thanks
Old Dec 31, 2007 | 05:48 PM
92slowmaro's Avatar
well here is my opinion on this. if your putting heads on the car your right there so you might as well put some in.
if i was gonig to do a cam only swap i would like to put new lifter in because i wouldnt want to put a fresh cam lobe on a lifter that might possibly have a warn roller. but i probably would leave the lifters in because who wants to pull heads when you dont have too.
its all preference.
ryan
Old Dec 31, 2007 | 05:53 PM
408Maro's Avatar
hmm well im in a dilema then because im about to swap heads/cam in my 02 and dont really have $400 for lifters at the moment but since im already there i should do it i guess ill just wait till i get the lifters
Old Dec 31, 2007 | 06:20 PM
92slowmaro's Avatar
what lifters are you looking at for 400 bucks? the badass cadi racing lifters are only 250ish.
Old Dec 31, 2007 | 06:40 PM
Gary Z's Avatar
Default GM Racing Hydraulic Lifters
https://ls1tech.com/forums/generation-iv-internal-engine/580686-new-upgraded-hydraulic-roller-lifters-sdpc.html
Old Dec 31, 2007 | 07:33 PM
massls1guy's Avatar
I used the LS2/LS7 lifters. They perform well for most people (under 7kRPM) and are great deal at $100:
http://www.sdparts.com/product/12499...esSetof16.aspx
Old Dec 31, 2007 | 07:45 PM
98TA_vert's Avatar
I got'em
Old Dec 31, 2007 | 10:07 PM
LS1Silverado05's Avatar
Originally Posted by 98TA_vert
I got'em
Yep...me too
Old Dec 31, 2007 | 11:09 PM
Slo-Mo-Shun's Avatar
Originally Posted by LS1Silverado05
Yep...me too
+1, I just need to get mine together.
Old Dec 31, 2007 | 11:18 PM
dab2pds's Avatar
i use morel lifters, and they are holding up well to a lot of abuse
Dave
Old Jan 1, 2008 | 02:33 AM
One Bad Z's Avatar
could prolly get by with the heads/cam swap without changing lifters. I didnt change lifters when i put a cam in neither have alot of other people. Down the road if there is another cam change that would be a for sure time to change the lifters.
If time isnt a problem could just hold off on the heads/cam install until you have the $ for a set of lifters. Maybe a set of arp head bolts or head studs aswell.
Old Jan 1, 2008 | 02:41 AM
BayAreaSS's Avatar
Just buy the ls7 lifters and then do the swap. You're going to be right there so you might as well swap them out
Old Jan 1, 2008 | 07:32 AM
RGKSR's Avatar
Default GM Replacement Lifters
+2 The GM replacement lifters are working fine in my 402. You can get them for about $100.00 from SDPC.
Old Jan 1, 2008 | 10:30 AM
408Maro's Avatar
thanks guys thats great info im for sure ordering those ls7 lifters for my setup now if there around $100. i was just looking on TSP's website since thats who i got my setup from. im getting a ms4 so would those ls7 lifters still be fine? thanks
