All forged ls1(98 ss engine type)
That being said, I would expect at least 400 horse to the wheels using a 383. Thats actually a decent cam for an NA build. But, the choice in cam might not be ideal for a turbo with that much overlap, using such a narrow LSA. This is a hotly debated theory though, and might prove to be incorrect. But for the longest time, people have been running wider LSAs, shorter durations, and more lift.. From what I have seen anyway.. Although, I do like the fact that you are using a reverse split, and favor the exhaust a bit...
ANd also the pistons are stock size and only heads and intake are gona be different from the setup i had before and the stroke of course. The Best V8 Stories One Small Block at Time
But I say again, with the 241 heads, and extra cubes being your only improvement, I would expect a bigger increase in torque than I would in horsepower.
And because it is a stroker you should really try to do something with the heads as they will be a large restriction.You could pick up a lot of power with a set of budget heads like patriots or even ported stock castings.And with the 110 Lsa on the cam really try to get that compression to at least 11 to 1.Hope this helps
