SCR10.23-7ccs=????
Old 01-20-2008, 10:47 AM
jkwalkercchs's Avatar
Question SCR10.23-7ccs=????
Compression: 64cc - 10.23, 66cc - 9.56, 70cc - 9.77
Compression Height: 1.315
Bore: 3.902
Rod: 6.125
Pin Size: .927 x 2.500 - 118 Gram Pin
Ring Grooves: 1.5mm 1.5mm 3mm
3.0cc Valve Reliefs
Manufactured from Forged 2618 High Strength Alloy.
im totally lost any help would be appreciated
my heads are 57ccs so what would this equal??
Old 01-20-2008, 11:08 AM
405HP_Z06's Avatar
Bore: 3.902
Rod: 6.125
3.0cc Valve Reliefs
What bore, stroke, and how far down is the top ring from the piston crown? What head gasket do you plan on running?
Old 01-20-2008, 11:11 AM
stock gm gasket
idk i havent bought them yet i just need a rough draft estimate
stock stroke
that bore size 3.902
Old 01-20-2008, 11:17 AM
can the 5.3 be bored to 3.902
Old 01-20-2008, 11:26 AM
405HP_Z06's Avatar
The stock bore on the 5.3 is 3.780" so I don't think your going to get to 3.902".
Old 01-20-2008, 11:32 AM
well people get to the ls1 bore how much more is that
Old 01-20-2008, 11:39 AM
405HP_Z06's Avatar
Stock LS1 bore is 3.898". I'm not familiar with the 5.3, so maybe you can get 3.902".
Old 01-20-2008, 11:41 AM
yea maybe theres alot of cylinder wall on those people bore them to 3.898 all the time
Old 01-20-2008, 11:44 AM
405HP_Z06's Avatar
Just because people do it doesn't mean much. Has anyone done this and had the bores sonic checked for adequate thickness?
Old 01-20-2008, 11:48 AM
hmm idk u are right
wouldnt that be a slighty bored or maybe even honed ls1 bore
Old 01-20-2008, 12:01 PM
405HP_Z06's Avatar
hmm idk u are right
3.902 is a honed LS1 bore.
Old 01-20-2008, 12:19 PM
ok so i think that is achievable
Old 01-20-2008, 12:29 PM
JimMueller's Avatar
I come up with 11.197:1, not accounting for the space between the top ring and the piston crown so it might be a smidgeon lower.
Chamber 57cc
OEM compressed gasket .056
Gasket bore 3.902
Deck clearance .007 above deck
Stroke 3.622
Bore 3.902
Piston 3cc dish
Rod 6.125
Old 01-20-2008, 02:53 PM
i think they are flat tops
Old 01-20-2008, 03:00 PM
405HP_Z06's Avatar
Assumptions:
1. stock 5.7L head gasket
2. piston .007 above the deck
hey thats cool where did u get that?
thats totally achievable on pump gas with a good tune right
Old 01-20-2008, 03:07 PM
405HP_Z06's Avatar
Compression Ratio Calculator - Performance Trends,Inc.
11.2:1 is no problem on pump gas assuming the tune is right. I'm currently running 11.31:1 and have no issues whatsoever.
Old 01-20-2008, 03:21 PM
well theres a gas station in town they sale 97 would it hurt to mix a couple gallons with 93
Old 01-20-2008, 03:31 PM
405HP_Z06's Avatar
Wouldn't hurt, but won't help either unless you optimize your tune for it. If you have issues with knock or timing retard, than it would help. Otherwise, your wasting your money.
Old 01-20-2008, 03:35 PM
o ok
im still tryin to decide if i want this motor in my truck or a gbody
