slight knocking noise??
Old Jan 1, 2008 | 04:46 PM
Ricky_GD's Avatar
Default slight knocking noise??
Hi havent posted on here for a while but i have a GD cobra with a stock ls1 engine in (for the moment ) the engine has been in for a while now and has been running fine been on the dyno and put out a nice 340 BHP flywheel (360 on race fuel ) but now i can here a very slight knocking noise coming from the engine its hard to pin point where its coming from but it sounds like a bottom end knock, im sure it cant be the noise goes after a slight rev and is fine when driving. oil pressure is 50-60 psi cold 30-40 warm ( i think havnt had it warm in a while) but there does seem to be some valvetrain noise also when reving... but i have herd this is fairly normall.
has anyone else herd of this? should i be worried?
sorry if its abit vage but somone may know what it is!!!
thanks alot
Ricky
Old Jan 1, 2008 | 06:17 PM
socmguy's Avatar
Restricted User
If it sounds kinda like a sewing machine, that is normal LS1 valvetrain noise. Have you revved it past 7K? That could be a problem with your rod bolts. Lets hope that's not it@!
Old Jan 1, 2008 | 06:22 PM
Ricky_GD's Avatar
yes almost.. its a rotaional noise that i hadnt noticed before. never been past 7000 well not since i have had the engine anyway !!
thanks
