wondering if anyone is running a similar cam
the specs are 228/232 with a 113+2lsa. THis is a custom ground cam and i have not been able to find anyone running around the same cam. My goals for my car are to run a mid to low 11's cam only. my mods so far are catback, lt headers and lid. Future mods are the cam, 373 gears, ls6 intake and a ported throttle body. any info on this setup will help
thanks
thanks
I run this cam on a 112+4. I like like it, makes plenty of power under the curve. To get the times you want, you will probably need a set of heads. I compared heads for months before I got mine. I was looking for bang/buck value. My whole setup is in the sig.
i was thinking about getting some heads, i will not be starting this project until the next winter so i have a lot of time to prep for it. Seawolf18, have you ran in the 1/4 mile with that setup yet?
I run the same cam as Seawolf except on a 110+1. It was designed as a TQ cam, I don't think you are going to see mid 11's with cam only. Invest in some good heads and you will be there brother!
J.R.
J.R.
thanks
thanks
