Replacing Crank/pulley seal On car?
If you don't want to do that, there's probably a seal puller that'd let you pull it with the timing cover in place and then you'll need something to help you tap the new seal in. Its a PAIN to get that seal out sometimes so it may just be easiest to suck it up and remove the pump and front cover.
If you need to replace the seal, I vote do it right and pull the cover.
Oh yeah, do you just put the cover back on, tighten and then pulley, or leave the cover loose, put pulley? I seen a post about this, but since you guys have doen it already, thought I would ask. Also, use silicone on the bottom of the cover to oil pan or no no??
Put a little oil on the seal both when your putting it in the cover and then some one the seal and the pulley when you put the pulley on. This will make everything go together easier.
I have to say I would do it like that Chris, hell i did once, but want to make sure I dont have to do it no more.
With a brand new seal, you dont have to center the cover. If you are going to pull off the timing cover and then reuse the seal, you need to have it centered, either with the fancy tool, or by not tightening the bolts on the cover until you put the pully on.
chris
Stick all the bolts in, make sure the seal is somewhat centered, and tourque down bolts. I havent leaked a thing. The cover moves a bit but not that much, it is possible to do it by eye.
