Checking PTVC. Let me know if this sounds right.
So now that I have written this novel my questions are do I need to have the head torqued to 30ftpds or more to check this acurately? And did I set the p rod length right by having it tight when at TDC on number 1. Thanks for all your help.
2. use a head gasket with the thickness ur going to be using for final assembly, if not do the math according. Run head bolts down to snug.
3. adjust the rockers to 0 lash, that means no preload on checking springs. you will turn your 8mm bolt untill you feel all the lash/slack go away in the geometry. if you go a little bit to tight(past 0 lash) you will open the valves ever so slightly. u will be able to see and feel all of this.
intake= adjust intake rocker to 0 lash when exhaust rocker just starts to open.
exhaust= adjust exhaust rocker to 0 lash when intake rocker when intake valve is 3/4" of the way closed(on the closing side of the intake stroke).
lash= with your checking springs in place and when your valves are at the closed position after you have lash them, there should be no preload on checking springs.
4. roll the motor around clockwise to when the exhaust valve begins to open and keep rotating untill exhaust valve is on the closing side. Keep rotating till the exhaust rocker arm continues to close, and stop the degree wheel at 10* BTDC, and put a dial indicator on the exhaust spring retainer, 0 dial indicator, push down slowly untill exhaust valve hits top of piston, and right down your reading. After you do that, continue to rotate engine slowly clockwise(u will see the intake rocker starting to move or already moving) and rotate the degree wheel to 10* ATDC, stop, put the dial indicator on the intake spring retainer, 0 dial indicator, push down slowly and take your reading. Hope you got atleast .065+ intake and .080+ exhaust clearance, if not you might want to think about flycutting, different thickness head gasket, or alter cam timing. hope this helps and good luck man.
Joe
