Okay I am out of ideas...I need YOUR suggestions.
Well basically, here is where I am sitting.
I have a 01 SS A4, right now I have a short block that is needing a heads/cam setup. I am going to be running a Yank 3800 stall converter, and 3.55 rear gears (ford rear-end).
I want this to be a fairly aggressive setup. I have been playing with Desktop Dyno 2000, and I have come up with some kinda cool cam setups. I know they are purely speculation, but soo far the one I like the best, is basically the GM Grand Am Cup cam, a 239/251 .580 .580 on a 110 LSA.
I am going to use LS6 heads that are ported and worked extensively, because I will eventually upgrade the shortblock to a stroker, and probably add forced induction (not sure which one 1st).
Soo, now you guys give me your advice based on my above ideas please!
Thanks!
TireFryer
Thanks!
TireFryer
Re: Okay I am out of ideas...I need YOUR suggestions.
Thanks!
TireFryer
Thanks!
TireFryer
If you only plan on using nitrous, I think ls6 heads and that cam are a great idea.
If you are doing a turbo/blower and not nitrous, I say go with 6.0L heads and a much smaller cam that will be compatible with your forged motor at a later date, and will also allow you to run a blower/turbo now before you run a forged stroker. By going with ls6 heads/big cam now, you cannot run a blower/turbo before you get the stroker. You are just limiting your options.
Hey Verbs,
I am actually going back to my original plan of sticking with a budget. I am probably going to do a stroker block within a year, then possibly add an S/C on top of that a little farther down the road.
Soo, for right now, I am gonna go back to my original plan of high comp. and a big cam.
