My Cam is on Backorder! Help me pick a new one please!!
If the heads have been milled the cams with over 230 duation will probably not work .. the cams with the duration in the 220s will not have p/v clearance issues with milled heads ... a 224/228 .588 112 LSA cam will still give him the performance he is looking for without p/v clearance issues..it does not sound like he wants to notch his pistons...
Check out this Futral Cam for sale on this board.
I know this is a kick *** Cam, and I have almost exact same setup as you, except I have 100k miles. With this cam and your setup, should come in around 430 to 450 RWHP. Also buying this cam will save you almost a hundred bucks.
Thanks for all the help guys. I ended up going with the TR224/224 on a 114. They had one in stock so I went for it. Good all around cam, with great manners. Thanks for all your input though.
