ms-3 or ms-4 questions
I know that MS3s and MS4s were designed to fit stock heads. I would say milling heads would really cut it close, which opens the door to PTV problems.
FWIW, I run 5.3L heads unmilled and they clear my MS3 by a red **** hair...the plus side to this set up is it does raise compression slightly and I did not have to mill **** thanks to ~62 cc combustion chambers
I would recommend you measure with clay or degree wheel and gauge. Otherwise, you are leaving the fate of your pistons in the hands of those whom you have never met
Erik
Keep your stock 241 heads, have your bud port em if he wants to do it for nothing (which is cool). Throw some dual springs on there and run something in the high 220's or low-mid 230's. I run an MS3 cam like I mentioned above and I really have to rev the **** out of her to feel that cam do its thing. Granted I race a lot and also plan on running a dual stage of nitrous, so the MS3 will eventually make sense lol.
Otherwise, I have a 228/232 on a 110+2 in the shop if I ever choose to build a street car with gobs of torque. The cam I mentioned is a popular grind that many here will atest to.
It all depends what you want to spend. Dollar for dollar, ported 241's and a decent cam make for a FUN, FAST, and powerful F bod!! Oh yeah, don't forget pushrods!!
Erik
). i was thinking something along the lines of the ms-3 would be a good choice over the ms-4 where as i wouldnt have to rev quite so high. but any suggestions are greatly appreciated.
Hell, if ya got the 4.10s and a 6 speed, by all means get the MS3, just get ready for power @ 7200 RPMS
Not sure how I know that lololFWIW, port heads, NO mill, run MS3- youll love it specially with 4.10s, I miss mine.
I would go with something that makes power all day long and will allow your motor to live longer than if you rev the **** out of it.
Everyone is always afarid that they will want to go larger. After driving and working on the cars that I have, I would say that the majority of the mid sized cams OUT PERFORM the "larger" cams 9 out of 10 times on the street.
Like I said, MS3s are sick with nitrous, especially at the track. Be realistic, how often are you going to rev to 6800-7000 on the street?
https://ls1tech.com/forums/showthrea...460&highlight=
Aside from the N20, his car is similar to yours and he has STOCK heads to boot! He made SICK power before the nitrous, and I swear the car was and is a blast to drive on or off the juice...something to think about man...he runs a mid 23x cam.
And oh yeah, he is over 100,000!
