Poll: best cam for the TRACK with stock heads?
Old 07-04-2003, 01:09 AM
  #41
02TranzAmWS6's Avatar
Default Re: Poll: best cam for the TRACK with stock heads?
Yeh really, thanks a lot niphilli. So if I were to get the tr 224 or the G5x2 how long do you think the rear end would hold up? And if anyone has dynoed after a 224 or G5x2 how much hp did you pick up?
Old 07-04-2003, 01:11 AM
  #42
When is this site going to get a chatroom?????
Old 07-04-2003, 02:18 AM
  #43
whatever's Avatar
I'm really not sure but doesn't the G5X2 require fly cutting the pistons or is that only for milled heads.
Old 07-04-2003, 07:24 AM
  #44
Fireball's Avatar
the rear is a sticky question. you can shred the rear to pieces with just a good clutch and a stock motor. Any cammed engine is gonna eventually kill the rear if you visit the track on a regular basis.
Like ragtop said...for max effort...230+ duration and a tight LSA (112 LSA or less) will net you the most power...just make sure you are geared for that much cam (4.10+)
