LS1 crank in a LS2?
Old Jan 8, 2008 | 06:26 PM
Lawnboy's Avatar
Restricted User
Default LS1 crank in a LS2?
Will a LS1/LS6 crankshaft work , installed in a LS2 6.0 L block , or is the LS2 crank different
Old Jan 8, 2008 | 06:36 PM
ls2 bait's Avatar
same crank diff reluctor wheel from what ive gathered.
Old Jan 8, 2008 | 06:47 PM
Randy WS6's Avatar
If you are planing to put a LS2 block in a LS1, you will need use a LS1 style crank to be compatible with the ecm.
