Cam is going in Friday
Old Jan 8, 2008 | 07:06 PM
b4ster602's Avatar
Default Cam is going in Friday
Right now I have a 00 TA basically with full suspension, lid, cutout, and borla catback. It has 64K miles.
Future Plans: Fast 90mm and throttle body. After that I won't be doing anymore motor work. Just want to get 410 or so to the wheels and sound good doing it with decent daily driveability.
Going in on Friday will be:
Pacesetter Longtube headers
Pacesetter off-road connection pipes
S cam- 238/240 on a 112 LSA 605/609 lift
Comp Cams *NEW* .650 lift 918 valve springs
Comp Cam 7.400 pushrods
NGK TR6 Spark Plugs
160* thermostat
Mobil 1 oil change
Price: 2076.12 with a tune and it will be ready by the end of the day.
I made another thread on this subject and have since decided to go stock rockers and lifters. I have been told multiple times that the stock oil pump should be fine, might go with an ls2 timing chain, or a double roller if I can get one for a decent price. I found an ls6 intake and ported TB for 350.00. I am kinda strapped for cash and was just wondering what you guys think of the setup and my plans (keeping in mind I won't be doing much of anything as far as the motor is concerned in the future).
Any help or advice will be extremely helpful.
Thanks,
Brian
Old Jan 8, 2008 | 07:22 PM
allthrotle's Avatar
should work out pretty nice for you, I made alot more then 410 with alot less. I think yours should be nice. I daily drive my setup and everything is golden.
Old Jan 8, 2008 | 08:17 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Seems a little more worthy of the internal section so I am moving it over there.
Old Jan 8, 2008 | 08:40 PM
b4ster602's Avatar
ya my main concerns deal with the stock timing chain and oil pump...anyone run them stock?
Old Jan 8, 2008 | 08:44 PM
ae13291's Avatar
man i mean ur tearing the motor down that much its good to just change it to be on the safe side! i know its not necessary but it sure is recommended! its like about a $100 for a new high volume one
Old Jan 8, 2008 | 09:21 PM
RIDINFILTHY's Avatar
i have my stockers , holding up just fine,i dont have much money so i dont spend it cause everyone says that i should!!!!!
Old Jan 8, 2008 | 10:43 PM
allthrotle's Avatar
Im running the stock oil pump but, I replaced the chain. I should have replaced the pump since I was already in there but, Oh well the stock one is still holding up fine.
Old Jan 8, 2008 | 10:53 PM
b4ster602's Avatar
Ya, i'm getting a different opinion from everyone. I would like to replace the pump, but HPE wants 100 for the pump and 88 for install. I'm a little short on cash. As it is, I'm gonna have to wait on an intake, which sucks.
Old Jan 8, 2008 | 11:18 PM
b4ster602's Avatar
ttt..
Old Jan 9, 2008 | 07:37 AM
lightemupls1's Avatar
i have a very similar set up going in on friday as well on my ws6 m6. lt headers, custom grind 230/236 .581/.590 112lsa. i went with the patriot dual valve springs, and pushrods. keep posting i would really like to hear what kind of numbers you dyno. i've had alot of people telling me 370-380rwhp on mine.
Old Jan 9, 2008 | 10:55 AM
allthrotle's Avatar
Well I say if you have alot of miles on the stock pump just go ahead and replace it but, if not then dont sweat it.
Old Jan 9, 2008 | 10:59 AM
Rushin's Avatar
Pretty big cam for a DD. Should work out nicely though.
Old Jan 9, 2008 | 11:01 AM
99FormulaM6's Avatar
your sig says H/C....i wouldn't consider that alot less that his S cam
Old Jan 9, 2008 | 12:50 PM
Vrbas's Avatar
I wouldn't gamble with your stock oil pump. Save the money you were going to spend on the double roller (just get the LS2 chain) and go w/ a Melling oil pump.
Old Jan 9, 2008 | 01:07 PM
RedRallyeZ's Avatar
personally id jump all over that ls6 intake mentioned earlier. with that cam's intake duration, you are definately gonna notice a difference. and even if your gonna buy a FAST later on, the LS6 is one of the few mods that holds its complete value 90% of the time, so buy it for $350 now and sell it for $325 when you get a FAST
Old Jan 9, 2008 | 04:33 PM
allthrotle's Avatar
I guess what I meant to say is I made decent power with alot smaller of a camshaft.
Old Jan 9, 2008 | 10:33 PM
b4ster602's Avatar
thanks i'll post dyno numbers when i get it back. I will definitely go with the ls2 timing chain. I'm still not sure if I'm going to keep the oil pump or not.
