Dart heads rev em how hard?
I would measure first then make decisions on what to do (maybe nothing). Like I stated earlier, the springs are excellent but you have to work within the parameters of their design. A valve spring height micrometer is an essential tool in my opinion. Only thing to watch, if you are over 1.800 (or think you are), make sure you buy one with enough range just in case. Some top out at 1.800.
I've decided to bite the bullet and have ordered the patriot Extreme valve springs, the guy who is buying my current cam can have the PSI's, they only have around 60 miles on them. So with my balanced Eagle crank and H rods, ARP bolts, what is safe revs? Just want to know so i can rev it on the rolling road till peak happens.
It's always something....
I've been in touch with Patriot and they have a spring locator that has a larger ID that will work with the heads, Cheers 405 for the tip off!
