Revised 918 Beehive Springs
Yeah. There is a post below this one about some guy who had really bad luck with them. They have been "fixed" how many times now and some people are still having issues. Comp is a good company but I'll never run 918's as there are better options for the same $$$$.
Comp addressed this and said there was a finishing problem that wasnt done correctly and that why a few batches broke.....Sometime poo happens boys,doesnt make Comp a bad company...
It is correct that u must decide on what install height your usuing but if u go by Comps install height I BELIEVE there rated to .625
https://ls1tech.com/forums/showthrea...ght=918+broken
And take a look at Thunder's site. It looks like they don't even sell them anymore.
Do u honestly think no other company has had issues?
Are u that blind,look at the valve issues that AFR had and cost them some problems
Look at Patriot...
They had some heads fall apart.
Look at Dart..
They revised there valve size once they new we didnt want Gen II valve sizing?
What about TX Speed
They had some porting problems with some heads and corrected it?
What about Futrals cams not being hardeded properly?
That was a issue too...
The point is POOP HAPPENS....
Sometimes its the companies fault and sometimes not...
Lastly if u think Comp makes the springs then u are sadly mistaken.There are about 3 or 4 companies that make springs for everyone,again sometimes things get overlooked and the consumer pays dealer...
Its sad but it happens not just in car modding but in life in general....
I'm done and off the soap box...
But YOU are entitled to your opinion
Look at Patriot...
Look at Dart..
What about TX Speed
But you are entitled to your opinion
I was just trying to point out that sometimes problems arise but it the good companies that step up and fix the issue when it happens...
Everyone one the the companies I previously mentioned fixed ALL of their issues..
I take my hat off tothem for correcting an honest mistake..
