Is 400 rwhp possible with this setup?
Old Jan 11, 2008 | 09:33 AM
JJ 86's Avatar
Default Is 400 rwhp possible with this setup?
98 vette mn6 with vararam, Tpis lt's, fast 78mm instake, x-pipe with high flow cats, b&b bullets, MTI G1 228/232... 113 lsa cam. My goal is to have good power under the curve but still have over 400 rwhp. The car will see very little track time and will mostly be street driven on the weekends.
Old Jan 11, 2008 | 09:35 AM
TXZ28LS1's Avatar
you should be close. but i would get the fast 90 over the 78!!
Old Jan 11, 2008 | 09:36 AM
rickyracer25's Avatar
it'll be close
Old Jan 11, 2008 | 10:27 AM
JJ 86's Avatar
Well I've got a pretty good deal on the fast 78 which is one reason as I'm considering the 78 over the 90. In the long run I'm going forced induction but I'm not sure if i want to get a magnuson, paxton or p1sc procharger. Would it still be beneficial to get a ls6 intake instead of the 78?
Old Jan 11, 2008 | 10:28 AM
teke184's Avatar
i think you'll make it....but i would expect much more than 400rwhp.
the fast will help make up for the smaller size of the cam.
Old Jan 11, 2008 | 10:30 AM
KONG's Avatar
420rwhp range.
Old Jan 11, 2008 | 10:33 AM
5.3LJimmy's Avatar
Go w/ the 78mm fast if you can get a deal on it as stated. That cam would put you at your goal and should make for a fun street car.
Old Jan 11, 2008 | 11:01 AM
JJ 86's Avatar
Is the 78mm fast that much better than an ls6 intake? If my goal is possible w/ the LS6 I may go that route instead.
Old Jan 11, 2008 | 11:30 AM
allthrotle's Avatar
If you can get a good deal with the fast then go with it, yes it flows more then an ls6. Could you hit your goal with an ls6? sure I think so with a good tune you should get what your looking for. If at all possible the fast 90/90 is superior to all for now, so go with it if you can.
Old Jan 11, 2008 | 11:38 AM
KONG's Avatar
Your goal will happen with an LS6. A fast 78 isn't worth the investment if your goal is 400rwhp. I have witnessed cars with similar cam grinds lay down 440+rwhp w/ 243 stock 243 castings. Keeping your combo simple with tried and true parts will get to your goal. Good Luck..
Old Jan 11, 2008 | 04:13 PM
Midnight02's Avatar
I think you can get to 400 rwhp with that setup; of course, now might be a good time to slap an underdrive pulley on as well and that should certainly help give you an extra 5 - 10 rwhp.
Old Jan 11, 2008 | 04:51 PM
99mongooSS's Avatar
yeah you probably make it
Old Jan 11, 2008 | 07:05 PM
418redz28's Avatar
yea that sounds pretty reasonable for that setup
