need help on spark plugs!
Old Jan 11, 2008 | 05:04 PM
Disturbed Bird's Avatar
Default need help on spark plugs!
its a high compression stage 2 PP LS6 head, 240/244/112lsa cam, ported F-90/90, 42# injectors and all bolt-ons.
what spark plugs do i need it should put down close to 550rwhp? N/A ONLY MOTOR!
and what gap?
Old Jan 11, 2008 | 05:05 PM
JPH's Avatar
JPH
i start off with NGK TR6, gapped at .035.
Old Jan 11, 2008 | 05:32 PM
ae13291's Avatar
i think the TR6 is used in forced induction applications! i could be wrong but get the Tr55 gap it around the .030's
Old Jan 11, 2008 | 05:37 PM
Viper's Avatar
TR6 at .035 to .040.
If you want to take a TR55 to that level buy the TR5, it is suited to go lower as it starts at .040 (I think) whereas moving a TR55 down to .030 is too much movement on the plug IMHO. The TR5 is the same as the TR55 (heat range) just smaller gap whereas the TR6 has a different heat range AND smaller gap. With high compression and a lot of HP, your better off with the TR6 according to NGK. I'm running them at .042 with 431hp.
Old Jan 11, 2008 | 06:00 PM
ok thanks im going to go with the tr6 right now. ihave used them when i was using no2 so i know what to expect
Old Jan 11, 2008 | 06:36 PM
JPH's Avatar
JPH
Originally Posted by Disturbed Bird
ok thanks im going to go with the t6 right now. ihave used them when i was using no2 so i know what to expect
good choice man. its always better to start cold first on a high compression motor, then work your way up in heat range from there if needed.
Old Mar 14, 2008 | 04:45 PM
DaddySS's Avatar
Reviving this one - on the NGK site they list the Z06 as coming with TR6s but gapped at .054? The "stock gap" for the TR6 is listed as .044? So for N/A 11 to 1 compression LS1 at about 400HP to the wheels (465HP at the flywheel) what is the recommended gap?
Old Mar 15, 2008 | 05:04 PM
DaddySS's Avatar
No one???
