Keying the crank?
Old Feb 4, 2003 | 01:15 PM
Black Sunshine/ 00SS's Avatar
Default Keying the crank?
Good idea? Needed?
Old Feb 4, 2003 | 01:37 PM
NoGo's Avatar
Default Re: Keying the crank?
You usually don't need to key the crank unless you are running a blower.
Old Feb 4, 2003 | 01:51 PM
Larry's Avatar
The crank has a key in it already but is liminted in the area of the lower timing chain gear. Too bad GM didn't bring the grove all the way to the front of the shaft. The crank pulley would be easier to get on and off were it keyed verses interference fit.
