What Went Wrong???? HELP
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
The coolant plug is directly behind the Exhaust manifolds last bolt (firewall side) on the passenger side , and right in front of the first manifold bolt on the drivers side (coolant temp sensor goes there)
I suggest taking off the passenger side valve cover to get acces to the plug.
The plug should still be in your old head It takes a 6mm or 8mm allen wrench to remove.
Brent
