H/C ordered, did I miss anything?
Originally Posted by DTB_LS1
You might want to think about upgrading your fuel pump. Racetronix makes a great kit that is fairly cheap and it always helps to be on the safe side.
DOnt forget the threaded plug on the side of your head. I was overheating and discovered why! The plug didnt come with the 5.3 heads. I have to re use my old one and the other plug is where the coolant temp sensor plugs in..
http://www.ws6project.com/user_stor/...1b34e814a34803
thier called coolant plug seals it comes with 4 of them one on each side front and back between the heads back ones are just plugs your front has the small tube on it. Just the little things while your thier might as well change them.
