Car is having trouble idling...lots of surging.
Old Jul 4, 2003 | 06:46 PM
ScottyG's Avatar
Default Car is having trouble idling...lots of surging.
Mods are in sig. The car has always had a little surge with the TR230 cam, but it has started surging really bad and dies fairly often, especially in the first few minutes after startup.... hot or cold.
I've done a PCM reset and an idle relearn (tried more than once) and it hasn't changed even after driving a few hundred miles
Any ideas? Plugs maybe? I have about 10k on some TR6's.
Old Jul 4, 2003 | 07:22 PM
VINCE's Avatar
Shorty Director
Default Re: Car is having trouble idling...lots of surging.
any loose hoses...? sounds like vacuum..
Old Jul 4, 2003 | 09:42 PM
Slowhawk's Avatar
LS1Tech Sponsor
Any tuning done to it?/
Old Jul 4, 2003 | 09:53 PM
ScottyG's Avatar
I'll check over the hoses tomorrow.
MTI did the tuning.
Old Jul 4, 2003 | 10:41 PM
98TAauto's Avatar
10k is alot of miles on TR6's. I'd just switch those out anyway for performance issues. I believe most change them every 3-5k.
But check the hoses that go form the valve covers to the intake and etc. Might be a leak. Also just check and make sure the intake bolts are all tq'ed down good.
if not, maybe the hooter weather has played some effects on the car. I mean did the car just start to get worse in the warmer air?
might need higher idle, tb drilled a little more, or some timing added in park. That cam can be a PITA in some cars from what I see, but mostly A4's
good luck and wish i coulda helped more
Old Jul 5, 2003 | 04:48 PM
JaSSon's Avatar
Hey Scotty sell that thing and buy a Cobra like everybody else is doing. Just kidding, call if you need any help. Jason
Old Jul 5, 2003 | 05:33 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
I'd like some hooter weather!
Old Jul 5, 2003 | 07:55 PM
Gold Phoenix's Avatar
I had a set of Autolite plugs that were a step colder for my nitrous setup and I went 40K and several bottles of the juice before I changed them and they didn't show anything major and wore only alittle.
Old Jul 5, 2003 | 11:06 PM
ScottyG's Avatar
10-4 on the hooter weather :p
Old Jul 6, 2003 | 12:49 AM
Smoke_Ford's Avatar
Definetly sounds like a vacuum problem. Measure engine vacuum at idle, you need at the very least 17 Hg.
