View Poll Results: Trickflows, Darts, AFRs
Trickflow
51
38.93%
Dart 225
13
9.92%
AFR
67
51.15%
Voters: 131. You may not vote on this poll
Trickflow vs. Dart Vs. AFR
Old Jan 22, 2008 | 01:19 PM
  #41
vader99's Avatar
Originally Posted by TEA Tech
...Stock heads have powdered metal guides, we have seen less than .0001" wear in 100K miles, as opposed to .002"-.003" wear in 10K miles on the bronze guides. Hope this helps.
Thanks for the help. So what is the advantage of using bronze guides over the stock powdered metal ones?
Old Jan 22, 2008 | 02:00 PM
  #42
TEA Tech's Avatar
Bronze guides are an industry standard, the initial sizing can be tighter and they have higher lubricity. There are several things that make powdered metal guides more difficult to work with, availability being one of them.
One huge factor in service for TFS is their 215, 225 and 235 heads are ALL in stock and on the shelf at Summit, and any TFS dealer can order them today and they will ship today. So you can buy them today and they will ship today, you can also get a Summit speed card that has interest free financing for 1 year with any purchase over $500.
Old Jan 22, 2008 | 05:12 PM
  #43
PewterScreaminMach's Avatar
I've never seen anyone go wrong with a nice set of Trickflows...
Old Jan 28, 2008 | 01:08 PM
  #44
vettenuts's Avatar
I have to agree with the roller rocker comment. I am currently running Darts and will be switching to AFR's soon. When I set up the Darts with stock rockers, the wipe patterns were horrible and some were even off to the side. Couple that with the higher spring loads required for faster aftermarket cams and I think the valve guide wear will suffer accordingly, what ever head you choose. I am currently running Crane rocker arms and the wipe pattern is one of the reasons. I spent a lot of time on the work bench playing with the wipe pattern of the stock rockers and the Cranes, in the end I couldn't get the stock rockers even close. I have found the same with Yella Terra, much narrower wipe pattern than stock buy you must spend the time to set them up and not just bolt them on.
Are they necessary (can't speak to the TFS heads)? No. Are they recommended? I would strongly recommend them for any higher valve spring loads even on GM heads. But this is just my opinion. The final hp number is not the only reason to consider the roller rockers.
Old Jan 28, 2008 | 01:12 PM
  #45
SSMOKIN_Y2KSS's Avatar
afr's for sure
Old Jan 30, 2008 | 11:40 AM
  #46
Jwahdan's Avatar
Hey guys sorry it took me so long to respond, ive been real busy. Thanks for all the input i think i want to get the trickflows, but ive been talking to a couple of guys that say the darts go with my cam so itll be the best for my setup. Is that true or are the trickflows still ok top put on my car?
Old Jan 30, 2008 | 11:49 AM
  #47
JL ws-6's Avatar
Race your car!
I put a set of ET 's on my 402, and if I had to do it all over again, I'd put the same ET's on it again. They may be a little harder to come by, but in the end, they're an excellent quality piece and there's a version out there for everyone.
Old Jan 30, 2008 | 11:57 AM
  #48
CraZee ZO6's Avatar
best heads out for these cars...
ET Performance heads are top notch quality and make great #s n/a and boost.
Trickflow again top notch I would say very comparable quality to ETP heads but the trickflow 215 head are making the MOST power n/a.
For boosted application I would choose either head but for n/a trickflow.
AFR is last years news good head but not the newest stuff making better power.
all imo... from my research as a avid SBC modder.
Old Jan 30, 2008 | 12:01 PM
  #49
CraZee ZO6's Avatar
Originally Posted by 07BlueDevilZ06
Anyone know what the highest hp out of a stock 346 is with a heads cam combo is? I thought it was tea/tfs combo like 515hp.
George
Would be nice to crack that # Im close but short of a fast intake setup!
Old Jan 30, 2008 | 12:11 PM
  #50
Abdullah's Avatar
trick flow 215cc CNC heads will be better than darts.
Old Feb 8, 2008 | 11:07 AM
  #51
Jwahdan's Avatar
So with my setup the trickflows would be the best heads out of the three? I only ask because some people say the trickflows arent as good as darts because of my setup.
Old Apr 22, 2008 | 02:18 PM
  #52
CraZee ZO6's Avatar
do those people have trickflow heads? how do they know about whats going to happen with your setup and those heads?
probably just bias because they have dart heads and they dont want you to be faster LOL.
just realized i brought this up from dead.
Old Apr 22, 2008 | 09:53 PM
  #53
sf35thle's Avatar
Dead Threads are the best, I agree, go with Trickflows thats what I am going with YEA
Old Jul 21, 2008 | 01:58 PM
  #54
Tavarez's Avatar
AFRS for the win.
Old Jul 21, 2008 | 05:48 PM
  #55
matt1289's Avatar
I like AFR heads tbe best.
Old Jul 21, 2008 | 08:00 PM
  #56
BlkHwk's Avatar
I went with AFR's mainly due to the thicker deck and not having to go with a high dollar rocker set up, and they are an awesome head.
Old May 18, 2009 | 03:08 PM
  #57
jophuss36's Avatar
I almost have my tea tfs 225s on my truck with a compression bump from 10:1 to 11.65:1 my push rids should be in tomatrow and it will be a few weeks to save up 400 for a dynotune but il keep yaw posted
Old Jun 17, 2009 | 11:31 AM
  #58
brock1981's Avatar
How is the gearstar tranny holding up? I want to get one for my truck.
Old Jun 17, 2009 | 06:04 PM
  #59
Spectre86's Avatar
strong bump
Old Jun 17, 2009 | 09:02 PM
  #60
allngn_c5's Avatar
I started out stock (obviously) and went to AFR 205's, great head. So good in fact that I re used them on my 402. I found myself in a unique position to upgrade to tfs 215's and sell my afr 205's. Swap takes place next week. Stay tuned for an update.
On a side note I am being told the tfs 215's are going to maintain my strong lowend torque that my afr 205's provided and add mid/upper rpm HP that the afr's just couldn't because they were a little overwhelmed by the 402. Sounds like the best of both worlds.
Again stay tuned. Good looking out John (spectre86) for bumping this oldie but goodie.
