Any reason why an Auto Radiator could not be used as an engine cooler?
Is there any reason that I wouldn't be able to use the section of my radiator that is actually designated for the auto tranny fluid cooling for engine oil cooling in a T56 equipped Camaro?
I bought a BeCool radiator that is made for an automatic, I figure I could use the lower section for the engine oil cooling.
Here's some info on the pressures involved:
http://www.frrax.com/rrforum/index.p...&hl=oil+cooler
Here's some alternatives:
More info; sounds like modification is necessary to do this
Try more searches on frrax.com
