TSP 224 or 233 Cam?
Old Jan 17, 2008 | 12:24 AM
bigdaddy1010's Avatar
Default TSP 224 or 233 Cam?
Trying to choose a Cam for my A4 LS1 but want to stick with stock heads for now. I'm eyeing the TSP $599 package with the 224 Cam, but if possible with stock heads would like to step up to the $709 233 Cam package for better HP gains. So can I do the 233/239 with stock heads?
Old Jan 17, 2008 | 12:27 AM
99z28monster's Avatar
I believe you can go bigger than that if you want get the ms4
Old Jan 17, 2008 | 12:30 AM
kingsey's Avatar
depends on what stall u have
Old Jan 17, 2008 | 01:10 AM
green28's Avatar
What would be a good cam with a 3600 stall and stock heads?
Old Jan 17, 2008 | 01:54 AM
Exactly I will be getting a ss3600 stall.
Old Jan 17, 2008 | 01:59 AM
99mongooSS's Avatar
You can go with the ms4 cam if you want but yes the 233/239 cam will work.
Old Jan 17, 2008 | 02:24 AM
No problems with the MS4 with stock heads? Is the $709 kit that lifts to .660 enough or they still going to be stressed?
Old Jan 17, 2008 | 02:30 AM
99mongooSS's Avatar
when you install it check you ptv clearance, but yeah if they are unmilled ls1 or 6 heads it should work...thats what it was designed for. to be the biggest cam possible on a factory shortblock without flycutting the pistons if heads are still 65cc chambers of course. and yes the prc springs are great for that cam.
 Michael S. Palmer
Old Jan 18, 2008 | 04:55 PM
Would the 3600 stall be fine for an MS4??
Old Jan 18, 2008 | 05:23 PM
LS1BLKSS's Avatar
Banned Village Idiot
lol thats the same package im getting too! $709... did you get a quote how much shipping is?? or is it free shipping???
http://texas-speed.com/shop/item.asp...d=175&catid=49
Old Jan 18, 2008 | 09:07 PM
RedRallyeZ's Avatar
if your on stock heads, id look at the tr230 from thunder, reverse splits are great for stock heads cars, and a strong torque curve too
Old Jan 18, 2008 | 10:30 PM
John02Hawk's Avatar
I would get the 224 cam if it's your daily driven car, if not, get the 233 cam.
Old Jan 19, 2008 | 01:47 AM
conde'strans's Avatar
I just got me a 3600 and will be goin with the MS3 cam(TSP $709 package) for my daily driver soon! Will be keeping stock heads as well n there should be no problems!
Old Jan 20, 2008 | 10:24 AM
wilwhite2kss's Avatar
does this package come with the gaskets?
Old Jan 20, 2008 | 06:13 PM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
The 233/239 or the MS4 camshaft will both work excellent with that verter & stock heads. I personally like the power of the ms4, but you really can't go wrong with either setup!
http://www.texas-speed.com/shop/item...d=666&catid=44
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
