cheaper to do a iron block?
Old Feb 8, 2003 | 11:59 AM
Redline-Motorsports's Avatar
Default Re: cheaper to do a iron block?
Hey Mike!
We pulled off the heads and are making some compression changes as well as a porting change that has shown a 20 cfm increase in flow!
Should be back on the dyno in a couple of weeks. Shooting for 520!
Yes I agree a sonic test will be the best check. Didn't know if someone else has tried it!
How's your project?
Old Feb 8, 2003 | 03:54 PM
frcefed98's Avatar
Thanks MTI Roadster
Do you know what the stock 6.0 cranks stroke is? Can I have the stock crank offset ground to 4.00in? Or is this impossible? Sorry for my ignorance but I have little knowlegde when it comes to engine math and engine rebuilding. I would like to keep the project under a budget and if the stock crank can do I'll use it. It should handle the power I want from it. The 6.0 blocks still use the 6 bolt mains right?
Thanks,
J <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Feb 8, 2003 | 05:41 PM
BTL FED's Avatar
Stock 6.0 stroke is 3.622 same as the 5.7, the biggest I have seen a stoke crank offset groud is 3.72, and the 6.0 has the same mains as the 5.7 block, hope this helps
