Engine Torque question
Old Jan 19, 2008 | 10:53 AM
crazygn's Avatar
Default Engine Torque question
i'll be pull the engine apart soon and need to find out whats up with the torque spec. here is what it says
Crankshaft Bearing Cap Bolts (Inner Bolts-First Pass in Sequence) 15 lb ft
Crankshaft Bearing Cap Bolts (Inner Bolts-Final Pass in Sequence) 80 degrees
question 1] after the 15 lb ft , how do you find the 80* , is there something to use other then a guess lol
question 2] i have a 99 ls1, is that the First Design or do i go by the 2nd design specs
thanks guys
Old Jan 19, 2008 | 05:57 PM
crazygn's Avatar
anyone out there lol
Old Jan 19, 2008 | 06:30 PM
Ricky_GD's Avatar
thanks guys
question one... go buy your self a degree meter and you will be able to see how many degrees u are turning..
Old Jan 19, 2008 | 06:36 PM
Ricky_GD's Avatar
dont know q 2
