Problems with the Engine, Please Help !!!
Old Mar 14, 2009 | 09:56 AM
zx9rgreen's Avatar
Are those stock heads? I have seen this several times and every time the root cause was a machining problem. Being it is the first (or last bore) bore in the machining process I would look there. The tool could have had a chip or burr and caused an oversized condition of the pocket.
Old Mar 14, 2009 | 03:54 PM
camarojunky's Avatar
Your car probably set a code when the valve seat dropped. You should look at your freeze frame data and you will know what temperature your engine was at when it failed.
Old Mar 24, 2009 | 01:31 PM
zx9rgreen's Avatar
any updates??
