What camshaft?
Old Jan 19, 2008 | 05:42 PM
smask04C5's Avatar
Default What camshaft?
I have a nearly new LS6 engine and plan on transplanting most of the stuff in my signature, minus the short block and camshaft. It will be a 3.905 bore LS6 with Wiseco -3.2 cc pistons, a BRC 4 inch stroke crank with 6.125 Carrillo rods. Fast intake will be Mamofied along with necessary head work. Any ideas on a good camshaft for this combo would be appreciated. Thanks in advance
Old Jan 19, 2008 | 07:06 PM
allthrotle's Avatar
Look at the trick flow camshafts, I made good power with one, with close to the same mods you have.
Old Jan 19, 2008 | 07:29 PM
smask04C5's Avatar
I'd like to get the most from the 4 inch stroke (383ci) and not have to change the exhaust system
Old Jan 19, 2008 | 08:02 PM
Top Fuel's Avatar
something T-Rexish in size
Old Jan 19, 2008 | 08:12 PM
Brad Hutchcraft's Avatar
He couldnt run the Trex with the 1.8 ratio rockers. But a cam that I would be looking at, would be something similar to the F12 cam from Futral on a 112 LSA. It gives a little more exhaust duration, would put you right in the meat of your powerband with that converter, and finishes up at around 6800 rpms. Seems like it would work well with the FAST manifold and the balanced performance of the AFR heads. I think it would make for an awesome car!
Old Jan 19, 2008 | 08:47 PM
smask04C5's Avatar
I've got a set of 1.7 Jesel SS rockers, just would need to clearance the valve covers. T-rex be a good choice with a good tune?
Old Jan 19, 2008 | 08:49 PM
Top Fuel's Avatar
sorry I didnt notice the 1.8's. So I'll change my statement. Ditch the 1.8's and get something T-Rexish in size . Trust me, I cant give out his screen name or too much on his setup because he street races, but my friends has a ported stock casting/Trexish size cam/383, 34-3500lb rw, 4000 stall, 4.10 combo and it runs. Doesnt dyno that well, but It ET's. A little better than the time i have posted. I dont how extreme you want to go with your setup, but i figured that since you were popping for a ported FAST, that I would throw it out there.
Old Jan 19, 2008 | 09:15 PM
^^^^^^^HAAAAAA!!!!!^^^^^^ funny!
Well, with a 1.7 ratio, and with that good of a rocker, maybe you should check into a custom grind... I mean, you have all of this money into the AFR heads and ported FAST, then why not get a camshaft tailored to YOUR needs?
Old Jan 19, 2008 | 09:39 PM
smask04C5's Avatar
What about a LG cam, perhaps a G5X2 on a 114 lsa?
Old Jan 19, 2008 | 10:59 PM
Top Fuel's Avatar
I'd imagine a g5x2 in a 383 would act like something along the lines of a 222/230 in a 346.
Old Jan 20, 2008 | 09:11 AM
Shawn @ VA Speed's Avatar
get a custom grind-you will never get the most with a shelf cam-we sell custom grinds for $370.00 pm me and we can talk about it.
Old Jan 20, 2008 | 06:18 PM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
We've done extensive dyno testing with 383cid applications & I personally like the driveability of the 244/248 XER camshaft on a 114. That combo has made 500rwhp before in a street car with good street driveability. Give us a call so we can discuss some of your goals & I bet we can help you get the most out of that 383 setup!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Jan 20, 2008 | 06:47 PM
99mongooSS's Avatar
X2 in that range.
