Swapping LS1 heads for LS6 heads............
Old Jul 6, 2003 | 09:02 PM
Joker # 9's Avatar
Default Swapping LS1 heads for LS6 heads............
This will be done on a 01' LS1. Is it just a straight swap? or is there more involved than just taking out and replacing the heads? Any one have or know of a write up on how to do the swap? Thanks!
Old Jul 6, 2003 | 10:46 PM
Jason99T/A's Avatar
I can shift faster than you.
Default Re: Swapping LS1 heads for LS6 heads............
The LS6 heads are a direct bolt on for the '99+ cars. The '98 cars would require the '99+ valvecovers and PCV system.
Check out www.ls1howto.com for actual instructions on doing the head swap.
