destrokin my ls1
Old Jan 20, 2008 | 07:50 AM
jkwalkercchs's Avatar
Arrow destrokin my ls1
im thinkin of putting a 4.8 crank in my ls1
anyone here tried that?
was there any gains?
Old Jan 20, 2008 | 09:06 AM
Shawn @ VA Speed's Avatar
no replacement for displacement-keep the longer stroke,lose torque with shorter stroke-torque is what gets the job done
Old Jan 20, 2008 | 10:24 AM
hey thanks i figured that would be the answer
i am havin trouble with figuring out what rod length i need for a ls1 bore on a 5.3 truck block
Old Jan 21, 2008 | 12:46 PM
zman1969's Avatar
Default rod
i think they are the same length - the longer the better if you have a choice as it reduces cyl wall thrust and distortion
Old Jan 21, 2008 | 02:05 PM
Russ K's Avatar
A 5.7 has a 3.897-3.898 bore. A 5.3 bore is 3.779-3.78, are you sure that you can bore the cylinders .118 oversize?
Russ Kemp
Old Jan 21, 2008 | 03:39 PM
you can bore the cylinders to a 5.7,and they do have the same rod length stock,i would recommend 6.125 rods,give you less side loading on the cylinders
Old Jan 21, 2008 | 11:15 PM
cellulis44's Avatar
YEA!!! bore that sucker out... you could go 4.8 all forged internals... 13.0:1... nasty cam.. shift at at 7500... lots of nos.. HAHAHA little screamer
Old Jan 22, 2008 | 12:47 PM
that sounds fun
 Michael S. Palmer
