24X trigger orientation
Old Jan 20, 2008 | 07:36 PM
proautoman's Avatar
Default 24X trigger orientation
Iam running an 05 Northstar 4.6 with LS1 Camaro PCM. Customers 67 Firebird-- I know
he should have done an LSX something. He wanted to be different? I have to mount the
24X trigger wheel on the Crank/ Balancer of the Northstar by filling the center that goes
on the crank and drilling a center hole and three alignment holes. Them mount the CKP
to the correct orientation-- If any one knows what tooth the CKP sensor is aligned with to the 24X wheel when the LS1 #1 cylinder is TDC compression- I will make the CKP mounting adjustable to correct small timing issues but I need to be close on the CKP to #1 TDC orientation
Any help ??
Old Jan 20, 2008 | 11:26 PM
proautoman's Avatar
Default Anyone
Anyone with the pan off and the ckp sensor out note the line up of the reluctor wheel
Thanks in advance
Old Jan 21, 2008 | 10:20 PM
proautoman's Avatar
Default Anyone
Anyone with the pan off of an LS1 with 24x wheel mark the tooth lined up with ckp and post it???????
Old Jan 22, 2008 | 09:41 AM
proautoman's Avatar
Default Anyone
added a pic if helps
Old Jan 22, 2008 | 10:51 AM
ArKay99's Avatar
I have my crank bagged in the cellar. I'm at work, but when I get home I can take a look at it for you.
Old Jan 25, 2008 | 09:39 AM
proautoman's Avatar
Anyone ???
Old Jan 25, 2008 | 05:01 PM
1FastBrick's Avatar
I have only seen how it lines up on the LS1 crank it self...
http://www.automotiverebuilder.com/ar/eb040538.htm
Not sure exactly were the sensor would end up in relation to the wheel at TDC.
Perhaps you could contact a site sponser that builds motors and they could maybe get you a picture of it from one of there engines.
Attached Thumbnails 24X trigger orientation-040538h.gif   24X trigger orientation-040538i.gif
Old Jan 27, 2008 | 12:09 AM
proautoman's Avatar
thanks that helps for which way still need tooth line- up with #1 tdc
Old Oct 8, 2011 | 09:55 PM
McConnell635's Avatar
Default #1 cylinder location on a 24x reluctor wheel
I am looking for the same thing as for where the #1 TDC is located on a 24 tooth reluctor wheel. I am converting a 401 Buick Nailhead to have the ls1 system on it. But I am having trouble with the #1 tdc location for the relutor wheel. I was hoping that someone might know by now.
Old Oct 9, 2011 | 06:26 AM
chrisfrost's Avatar
I hope this helps guys 24X trigger orientation-cimg0002.jpg all 4 images are with the #1/2 rod journal pointing straight up
Old Oct 9, 2011 | 08:59 PM
S10xGN's Avatar
Does a Northstar share the LS firing order? Does it even matter? Just something more to ponder on...
