Will this Combination spin to 6700 RPM without Valve Float?
Old Jan 21, 2008 | 01:39 PM
Gary Z's Avatar
Default Will this Combination spin to 6700 RPM without Valve Float?
Comp XER 228/230 .581/.588 Cam
Stock (hollow stem) LS6 valves
Stock GM 1.7 rockers
GM 88958689 Cadillac Racing Lifters
Chromemoly pushrods
Titanium Retainers
PAC 1518 Beehive Springs
All comments will be apreciated.
Old Jan 21, 2008 | 02:02 PM
JPH's Avatar
JPH
Chromemoly pushrods
Titanium Retainers
shouldn't be a problem, what are the pressures for those springs? Cam will peak way sooner than 6700k FYI.
Old Jan 21, 2008 | 02:58 PM
Gary Z's Avatar
Originally Posted by JPH
What are the pressures for those springs?
PAC 1518 Springs are similar to Comp 918s - 130lbs@1.80in, 321lbs@1.20in, 318lbs/inch, 0.650 max lift
Old Jan 21, 2008 | 03:18 PM
JPH's Avatar
JPH
good. Should be fine, especially with your lightweight valves and your other lightweight valvetrain components.
Old Jan 21, 2008 | 03:30 PM
Gary Z's Avatar
Thanks JPH. I’ve been concerned because I have the PAC springs and Ti retainers but Comp literature seems to recommend dual springs for all XER lobes – I can’t find a specific recommendation.
-Gary
Old Jan 21, 2008 | 03:38 PM
Yeahdoug's Avatar
With that lift you can install the 1518s at 1.750 for some extra seat pressure.
Old Jan 21, 2008 | 03:43 PM
Gary Z's Avatar
Thanks for the suggestion - I'll do it.
Old Jan 21, 2008 | 08:13 PM
LS1MCSS's Avatar
Chromemoly pushrods
Titanium Retainers
Are you sure you have the lift listed right? The Comp Cams master lobe catalog shows those lifts to go with a 224/228 XER, or is it a custom grind?
Old Jan 21, 2008 | 08:51 PM
Gary Z's Avatar
Lift is correct - I made a mistake on the intake duration. Cam is a Comp 54-444-11 224/230 .581/.588
Old Jan 21, 2008 | 10:19 PM
Brad Hutchcraft's Avatar
I really like the way that cam looks, what LSA have you decided to run it with?
Old Jan 21, 2008 | 11:03 PM
Gary Z's Avatar
Originally Posted by Brad Hutchcraft
What LSA have you decided to run it with?
LSA is 114, ICL will be 112
Old Jan 22, 2008 | 01:33 PM
BigKap94z's Avatar
My cam is a bit larger then that with chromoly retainers and PAC 1518's installed at 1.75" and have no valvefloat problems. Stock lifters, and stock GM valves(not lightweight LS6 valves) are what i use as well so I don't think you will have any problems.
Old Mar 21, 2008 | 11:37 PM
thechad's Avatar
Is the pac spring the same/made by PSI ?? Seems like its a LS1511ML (1511).. PSI springs are great from what I've heard/read and can be had for less, if you deal with them. I believe Katech uses the 1511 in alot of there builds except the c5 program which I believe used a LSM 422
Old Mar 22, 2008 | 03:18 PM
Yeahdoug's Avatar
We make our own springs.
Katech uses some of our higher end stuff for their C6R program.
PSI was started by ex-PAC guys. Just a fun fact.
Old Mar 27, 2008 | 11:15 PM
Tom@SpeedInc's Avatar
PSI 1511 looks and functions entirely different to a PAC 1518
round wire vs. ovate wire
IMO PAC springs are lot easier to get ahold of for a competitive price too, PSI's distributor is a small arrogant group out of NC <rant off>
Old Apr 12, 2008 | 08:53 AM
thechad's Avatar
Thats odd I just called em up and got em in 3 days?? Oh..... you sell pac springs and not PSI.. rofl
Old Apr 12, 2008 | 02:24 PM
N4cer's Avatar
People spin stock valvetrains (with upgraded camshafts) to 7k rpm every day without issues.
