Thoughts on this heads / cam combo?
Old Jan 21, 2008 | 09:15 PM
Gregg 00SS's Avatar
Default Thoughts on this heads / cam combo?
PP S2 035 casting heads with 2.02/1.57 valves and welded 59cc combustion chambers with a T-rex cam. Will I still probably need to fly cut or might these fit w/o cutting? Will my compresson be ok with this setup? I usually run only 93 octane in the car as is. Anything else I might need to be concerned with with going with a 035 casting vs a 243?
Old Feb 28, 2008 | 09:57 PM
THEE PEWTER Z™'s Avatar
ttt would also like to know
Old Feb 28, 2008 | 10:11 PM
98RedZone's Avatar
If they are welded instead of milled then it SHOULD fit. You need to find your DCR, but you should be ok with 93 octane and that cam.
edit: the bigger valves will be closer PTV
