Maximum lift on stock 243s ?
Old Jan 22, 2008 | 09:51 AM
DV327's Avatar
Default Maximum lift on stock 243s ?
What is the optimum lift that the untouched 243 head can use on the street through stock intake and exhaust manifolds? I am on the fence between the LPE GT11 or the TR CheaTR in my 05 GTO. Looking for stealth and best power.
Old Jan 22, 2008 | 11:52 AM
DANOZ28's Avatar
if your talking about springs/ lift i wouldnt go over 570 lift on stock ls6 yellow springs. if your talking about at what point would the valves touch the pistons i dont know , call TSP or patriot.
Old Jan 22, 2008 | 02:24 PM
DV327's Avatar
Thanks for the reply. I know that I will have to change springs. My question is how much lift can the stock head use? Does air flow diminish at .600 lift or can they effectively use more lift?
Old Jan 22, 2008 | 02:26 PM
orangefun's Avatar
Really Depends On Lsa And Duration Also
Old Jan 22, 2008 | 02:50 PM
ArklaTexan's Avatar
I am running a 244/242 .612/6.10 on 112lsa on Stock LS1 Heads with no problems, have for the last 10k and beating the heck out of it
Old Jan 22, 2008 | 04:51 PM
LS1IMPULSE's Avatar
whatever your springs can handle, but a stock LS6 casting intake peaks around 260CFM at .550 lift and back flows after that. Exhaust peaks at 195CFM at .600 lift and gains very little after that.
Old Jan 22, 2008 | 07:48 PM
black01_WS6's Avatar
the gt2-3 is good as well as the ls6 cam, don't go too big if you are using the stock manifolds.
