did some 02 fbodys come with the ls6 block?
Also seen a bunch of pissing matches on this site, people arguing that it doesn't matter.
Whether it matters or not there is one question being asked here -did some 02 fbodys come with the ls6 block? The answer is yes.
LS1TECH > WELCOME TO LS1TECH > New LS1 Owners - Newbie Tech
JRP's FAQ For Commonly Asked Questions
How to tell if you have an LS6 Block
15% of 01s and 25% of 02's got the LS6 Block. The only way to tell 100% is to check the casting number. As you can see in the above pic (my ls6 block
) the casting number is at the top of the deck on the drivers side. Take a mirror and place it behind the block and check or jack up the car and attempt to look from the bottom. The "easier" ways are the casting hue and bulleye methods but none are conclusive. If you really want to know if you have the block you'll need to do the work and look for yourself, end of story.Once you have determined if you have an LS6 block (ya you), then the only benefit to the block are the bay windows.
Its generally accepted from most engine builders that if your going for an extreme setup that the LS1 block offers more structural strength over the LS6 block.
THE LS6 BLOCK DOES NOT INCREASE HP, REPEAT AFTER ME "IF I HAVE AN LS6 BLOCK IT DOES NOT INCREASE POWER". LEARN IT, SAY IT, REPEAT IT.
SEE ANSWERING YES IS MUCH EASIER THAN BITCHING ABOUT A STICKY. YEA IT'S BEEN DISCUSSED A MILLION TIMES BUT 'YES' WOULD HAVE BEEN A THREE LETTER ANSWER. HEADED FOR THE WINDOW
smiley. Only one negative post in here so far...I'm sorry a yes/no answer is all that you wanted to see here, but since the OP had apparently not seen the info, or the sticky, I thought I might bring the info (along with where it's found) into the thread.
Sorry if the red letters hurt anyone's eyes, I just copied the images, text and formatting straight from the sticky.
And the clip was recorded at 26,000 miles.
Seriously, that sucks! I'm sorry to hear that you've got one of the noisy ones. My '01 SS makes a little noise at cold start, but it's gone in a minute or so. I'd be pissed too if I were in your shoes!
