where can I get the best heads for the money
Re: where can I get the best heads for the money
The Patriot Performance cylinder heads are VERY hard to beat! We still have the heads priced at $1,295 fully-assembled and ready to bolt on with dual valve springs and titanium retainers with 2.02"/1.57" valves. This is for the stage II porting and finish work. We also have the heads/cam package with your choice of TSP camshaft, stage II Patriot cylinder heads, hardened pushrods, and Rollmaster double-roller timing set for $1879.99. Now THAT'S hard to beat! We are shipping out six sets of Patriot cylinder heads tomorrow, so we'll be getting more and more results in the weeks to come.
Let me know if you have any questions.
Thanks!
Trevor
Thanks!
Trevor
I will be getting my new G5X-2 cam installed monday as well as my new 5.3 Stage 2 patriot heads, so we will have dyno numbers next week of the patriot heads with a big cam,
Our heads have been putting out really good results for the money. Some examples.
99 SS Auto, stock short block, 222/222 cam, all bolt ons
413rwhp/400rwtq
99 Z28 Auto stock short block, 222/222 cam, all bolt ons
413rwhp/403rwtq
98 Formula M6 forged 347ci shortblock
463rwhp/418rwtq
413rwhp/400rwtq
413rwhp/403rwtq
463rwhp/418rwtq
Patriot flow the same as TEA and cost $1295 with no core compare to $1700 and a core with TEA. Don't let the TEA guys tell you they are better. Bullshit. Texas Speed tested both and they were identical with out tubes. A lot of tea guys will quote you exhaust flow numbers with a tube attached. It makes a big difference.
I really need to make up my mind soon... like within a week or so about what heads I should get. I am leaning toward TEA, but Absolute is not out of the question... and neither is Patriot... if I could see some results from a big cam.
i have a set of absolute speed stage 2 heads with 60 miles on them that i have to sacrifice for 1200...no core required
email me if interested..
stik6shift98@team.camaroz28.com
2.02 1.75 valve
milled 25 tho
comp 918 springs
2.02 1.75 valve
milled 25 tho
comp 918 springs
6600 rpm clutch dump of death Administrator
Can some one send me some flow numbers on the TEAs and the Patriots so I can add them to my info sheet?
#34
Moderator
Just remember that flow numbers are not everything to buying a cylinder head. You have to consider what the port volume is and understand the impact to flow velocity. Two cylinder heads that may appear identical in flow numbers, however, have different throat diameters under the valves and also different intake port volumes depending on how the porter elected to cut the material to achieve the flow numbers. I'm not trying to persuade anyone away from "budget priced" heads but just consider all of the facts and the bottom line is performance.
The other factor is daily driveability. If a head has been hogged out for "good numbers" you run the risk of having runners that may be too large for "crisp" throttle response at low rpm on the street.
#35
Set of Patriot Stage II's (5.3L milled to 10/1000's) with a Futral 228/230 .578/.596 113 cam showed up in the big brown truck on tuesday. Should start throwing it all in this weekend. Maybe have some new numbers next weekend. ;-)
