New AFR 235 cc heads
Old Jan 22, 2008 | 08:21 PM
MOSTDELUXE's Avatar
Default New AFR 235 cc heads
I was just reading " Last hurrah " by Mr. Mamo and he mentioned a 235 cc head in the making. Has anyone heard of or about the new goods, and when they will be for sale to the public.
Old Jan 22, 2008 | 08:43 PM
bad2000z's Avatar
Hmmm...You got my attention.
Old Jan 22, 2008 | 10:14 PM
MOSTDELUXE's Avatar
Tony.....where you at big daddy I was just about to purchase a pair of 225 cc heads for my new combo and then I read "last hurrah" now the suspence is killing me.
Old Jan 22, 2008 | 10:23 PM
Tony Mamo @ AFR's Avatar
Flow Wizard
I am working on the design as we speak....in the home stretch but that doesnt mean they will be in Production anytime soon. I will say that the new combo I am building for myself personally will be running these heads and I certainly plan on having it in my car by the time the nice weather hits.
In the past we have disappointed some of you folks trying our best to estimate realistic release dates so I wasnt going to make a fuss about them till they are very close to a viable product we can take an order on. I dont want to hear people wining if we run into some issues that delay the release....therefore I wont promise anything.
Read between the lines though....there launch date is not 6-12 months away....hopefully just a fraction of that.
If you can wait abit they will be worth every minute you did based on the flow curve of my prototype....the last trick is to get a production piece of the CNC machine to do the same but Im confident given the time that we can nail it.
More to be posted soon....I will keep you guys in the loop
Tony
Old Jan 23, 2008 | 10:28 AM
1stz06's Avatar
Sweet deal......I need some of them on my next build.
J.R.
Old Jan 23, 2008 | 12:24 PM
VIPRETR2's Avatar
A six head bolt option would be killer.
Old Jan 23, 2008 | 02:50 PM
speedracer5532's Avatar
The 235 head will not be a 6 bolt head.
Old Jan 27, 2008 | 05:35 PM
Big Bird WS6's Avatar
and good if they work with the l76 intake lol
Old Jan 27, 2008 | 06:24 PM
bigsticksupra's Avatar
does AFR currently offer a six bolt head? if not, are there any plans to in the future to fit the LSX six bolt block?
Old Jan 27, 2008 | 07:51 PM
Flow Wizard
A six bolt head isnt necessary with a .750 thick head deck till well over 1000 RWHP....even then with the right tune-up its still an option. Im not saying it wouldnt be a nice luxury, but 99.5% of the people reading this wouldnt ever have the need for it.
The 235 will be a bolt on piece that accepts factory hardware (rocker gear etc.) and will not need a valve cover rail spacer either. It will bolt on as easily as a 205 or a 225 head we offer.
It will come with larger pushrod tubes drilled from the factory to clear a .375 pushrod as well as a 1.550 spring pad to accept a solid roller spring. Unlike the 205's and 225's, AFR will offer a solid roller package direct from the factory should you choose to order it that way. Its going to be very "solid roller friendly" which makes sense when you step into a head of this caliber. For the guys that want to stick with hyd. roller cams we will still offer our upgrade hydraulic 8019 spring and titanium retainer as standard equipment. There will be an upcharge for the mechanical roller set-up that will be good for up to .700 gross lift (perfect for a head that looks to peak around .600-.650 lift).
I will share more specifics about this product as it gets a little closer....
Thanks,
Tony
Old Jan 28, 2008 | 10:09 AM
tony
what size chamber will this head have. and how wil it flow boosted wise compared to your 225. i want your 225 until i head of this. so on a 18psi motor is it worth me waiting for this or just doing your 225.
Thanks,
Tony
Old Jan 28, 2008 | 12:09 PM
Flow Wizard
Originally Posted by Big Bird WS6
tony
I think it will work very well on a large boosted engine due to not only the added intake flow but more importantly the even stronger exhaust port. Our 225 already has one of the best exhaust ports on the market (when you eliminate flowbench variance and advertising BS), one of the reason they always put up big numbers in boosted applications, and the exhaust port in the 235 is even stronger by about 10-15 CFM from .300 to whenever you terminate the test (over our current 225 version). Its also a little larger and meant to be run with a 1.875 or larger primary tube diameter (a 1.75 tube may slightly hang into the port).
The only issue may be chamber volume for the boosted guys....the initial release will probably be around 64 cc'c but we plan on producing a 74 cc piece also to be released later. I would hate to have you waiting for months in the event it drags on. You could always get the 225's and sell them down the road after the 235's are in production if you dont want to wait.
Tony
Old Jan 28, 2008 | 12:29 PM
ChrisS@sdpc's Avatar
Nice info Tony. Can't wait to see the new heads. We already have a couple of projects in mind.
Old Jan 29, 2008 | 09:09 AM
98Z28CobraKiller's Avatar
Restricted User
You told me that I could have a set by the end of this month. I'm holding you to it.
But seriously, back to the 6 bolt stuff. Can you drill the heads for the extra top bolt? Would this hurt the strength of the head somehow? Would it help to keep the heads from lifting without adding the material required to use the one on the outside or would it just make the head lifting on the bottom more likely?
Old Jan 29, 2008 | 10:12 AM
ls2formula's Avatar
Show me a nitrous car that puts down well over 1000rwhp with 4 bolts heads.I have your 225s on my car with a 400 shot and push no coolant but I would like to try and spray what the sbc guys can spray and the 6 bolt heads would be nice.
How hard would be to add the 6 bolt to the casting?Trust me not many will be buying 4 bolt heads a year from now.
Old Jan 29, 2008 | 11:05 AM
Restricted User
Looks like the 00.5% have arrived.
Old Jan 29, 2008 | 11:15 AM
Flow Wizard
The .5% is out of luck....LOL
It would mean all new tooling and its not going to happen. The reality still remains that alot of folks are making close to or just above 1000 HP and not having major issues with the four bolt design due mainly to the integrity of our current head deck at .750 of an inch.
I dont argue a six bolt design wouldnt be nice for the small percentage that need it, but our cathedral Gen III stuff will probably always remain in a four bolt configuration.
Tony
Old Jan 29, 2008 | 11:17 AM
JPH's Avatar
JPH
you get a cam yet?
Old Jan 29, 2008 | 11:19 AM
Restricted User
Originally Posted by JPH
you get a cam yet?
Put it in on Saturday. Sending you a PM.
Old Jan 29, 2008 | 11:29 AM
Restricted User
Tony
Tony, I understand that you guys arent going to offer it. What I am asking is what is the downside to me having my machine shop do it if there is a down side?
