SCR and DCR HELP
I don't know anything about the vindicator, and you may have PTV issues. If I were you I would worry about getting a good quench height. Then have a cam custom ground for your specs and to get the DCR where you want it.
thanks.
Pistons .007 above the deck
Flycut pistons with 1cc volume
62cc heads, 3.910/.040 head gasket
59cc heads, 3.910/.040 head gasket
59cc heads, 3.930/.053 head gasket
TFS heads 64cc (will mill if needed)
.040 cometic gaskets
Vengence VRX3 camshaft 226/228 .585/.588 112
Not sure what other numbers you need. I was hoping to get SCR at 11.25:1 and DCR to at least 8.5. Or somewhere in this ballpark
1. Pistons .007 ABOVE the deck
2. Flat top pistons, i.e. NO valve reliefs
3. VRX3 camshaft has 0 advance/retard ground in, i.e. ICL = 112, IVC = 69.5
64cc heads, 3.910/.040 gasket:
62cc heads, 3.910/.040 gasket: (This gets you to your 11.25:1 static CR goal)
You would be best served asking the cam designer. Advancing the cam increases low end power, while retarding increases top end power. It's a delicate trade-off that really depends on your intended use and overall combination.
