Max Effort "MS4 vs Vindicator"
Old Jan 28, 2008 | 02:49 PM
ls1_doc's Avatar
I like the ms4 better than the trex although both are amazing cams. The Ms4 just seems more streetable to after having driven both of them.
Old Jan 28, 2008 | 04:10 PM
01 BERGER CAMARO SS's Avatar
I personaly been in an MS4 car and sounds and moves wicked. Ive never herd or tried using a Trex cam before. I dont rull it out but it might be soming I might look into for my C-10 project.
Old Jan 29, 2008 | 01:53 AM
Asmodeus's Avatar
Originally Posted by Asmodeus
How about a comp cams XFI286R113?
It's a 251/256 .660/.655 on a 113.
Go with this one, quit messing with small cams like the MS3/4, Trex, and Vindicator!
Old Jan 29, 2008 | 02:45 PM
1badzo's Avatar
i have to agree with some of these guys i would not pull the ms3 to go with the ms4 much less a vinicator if your going to do it do it go custom just my two cents
Old Jan 29, 2008 | 06:48 PM
well the max lift on my prc's is 660 and that lift is cutting it close. That be a geat cam to go with though. Besides, I rather do a custom grind when im ready for my 350 turbo setup and diffrent stall. Like i said before, this cam is not going to be in there for ever. I do plan on dropping it into my C10 once im ready for a custom grind
Old Jan 29, 2008 | 07:51 PM
NC98Z's Avatar
Originally Posted by 01 BERGER CAMARO SS
Max effort can mean alot to diffrent people. The reason I want to swap it out is because I have yet to drop in the motor and besides I want to slap the MS3 in my 01 Formula just for fun. I already have everything here at my shop to do the swap so why not. The set up im running right now is just to get the car on its feet and put down good numbers and track times with a max effort streetable cam. This is my shop car and want to be able to drive it like in my orginal post. Im not going custom grind yet cause im not done getting the MAX EFFORT out of my current set up. Test and trial have alot to do with getting the max out of your ride. Racing is about getting the right combo (Engine, Trans, Suspention and tune). When the time comes I will be swapping parts out for better ones. Hell there already here laying around in my shop LOL
OPPS somebody said the 3 letter word FUN!!! I call it rompability. When you can go by a car or a shop or the dealership! And romp at them. Now that ****s fun and thats what it all boils down to is. Agrability. If I can romp at sombody thats tried it before and lost. Then I've had a good day.
Old Jan 29, 2008 | 08:38 PM
Agrability, rompability J/K. Hey how do you like converter? Im looking for somthing in the same stall level.
Old Jan 30, 2008 | 10:38 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I'm running the Vindicator on the project Camaro and it's a strong cam. I've gone 10.92 @ 3350 raceweight with a nitrous-oriented torque converter and too much tire.
I'm going to be swapping out my current converter for an ATI 5500 stall which will hopefully get the car going around 10.5 or so.
This is on pump gas with 11:1 compression. 60ft was only a 1.48 on motor on the 10.92 pass and the car was going almost 100mph in the 1/8th which shows a lot of potenial.
Oh and it dynos like 415-420rwhp thru the unlocked TH400 converter.
Old Jan 30, 2008 | 10:59 AM
Ron@Vengeance's Avatar
Ima jump on the hate train and order a vindicator. I can wait to see this **** runn
Good choice
Old Jan 30, 2008 | 01:43 PM
99TransAmLS16Spd's Avatar
Not to side track, but will the MS4 even work with the prc 5.3 stage 2.5s? I went with the TSP ls6 1.5s as I was pretty sure the ms4 wouldn't work with the 2.5s because of the larger valves causing ptv issues. I could be wrong though.
Old Jan 30, 2008 | 02:23 PM
None of the cams listed will work with his cylinder heads unless he has notched pistons. Fortunately, the OP has a forged shortblock with valve reliefs so it opens the doors to alot of possibilites
Old Jan 30, 2008 | 03:28 PM
  #32
NC98Z's Avatar
I really like the stall if you were asking me. I blew a tranny last year and had Percision to clean it out for me and I had them to restall it to the same parameters.
Old Jan 30, 2008 | 06:23 PM
  #33
Yea, Ron is right. None of these cams will clear my heads, but my shortblock has 2cc flat top pistons so no worrie. I do later on plann on milling and opening up to bigger valves like a stage 3 and cometic gaskets to bump up my compression.
NC98Z, yea im looking for a converter but found one locally so all i need now is gears for my formula.
Old Jan 30, 2008 | 09:38 PM
  #34
Steve01SS's Avatar
I wouldn't bother swapping an MS3 with an MS4... You wont notice much of a difference if any. The vindicator is a good cam too, I like that TRex though. I've thought about it.. hehe. I would just pick the new cam for the new motor and just wait.
Old Jan 31, 2008 | 01:01 AM
  #35
Apollo0526's Avatar
one of comps customs grinds looks pretty good "SI7" 238 244 .605 .612 110
Old Jan 31, 2008 | 10:53 AM
  #36
CraZee ZO6's Avatar
Yea I like that cam spec alot too. Id just bump the LSA up to 113ish.
But out of MS4 vs Vindicator Id go for the vindicator. I like comps XER lobes not a fan of high lift LSK lobes.
