piston slap *WTF*
Old Jan 28, 2008 | 05:23 PM
black99ls1z's Avatar
Default piston slap *WTF*
so my car was makeing a tapping, knocking sound on cold starts and the noise would fade off as the engine would get warm. i checked the oil no problems there and the car has low miles so i just couldnt belave it had a bearing issue. my one buddy is a gm tech and told me the ls1 has a problem with piston slap. is this true. and if it is have any of u had any issues with this before and if i do have piston slap does that mean its time to tear her down and rebuild.... thanks
Old Jan 28, 2008 | 05:26 PM
Disturbed Bird's Avatar
yes thats normal. what you are hearing is it a ticking? all of them do it. nothing to worry about. unless it isnt stock than you need to check your piston to valve Clarence
Old Jan 28, 2008 | 05:30 PM
no it not a ticking it is more of a knock for the first id say 5 sec when i cold start it then it fades off pretty good
Old Jan 28, 2008 | 05:31 PM
whats done to the car?
Old Jan 28, 2008 | 05:33 PM
stangkiller2005's Avatar
my car does it do! i hate it! i can really hear it with cutout closed. It compleatly goes away once car is warm..but it annoys me when car is cold. people think its something wrong with my car. i tell them naw its normal. its called piston slap. and they look at me like i just called them an ******** or something..lol.. why do they do this?
Old Jan 28, 2008 | 05:34 PM
Cole Train's Avatar
My '98 Vette has a little of it too. It's NORMAL on most LSx based engines.~Cole~
Old Jan 28, 2008 | 05:36 PM
the car has slp intake and slp catback with punched cats i have a nitrous kit sitting at my garage but i didnt put it on cause of this problem what do u think
Old Jan 28, 2008 | 05:38 PM
spray the problem away!
what helps out with alot of people is change to royal purple 5w30 it almost eliminates. i dont have it. but iv ran RP since i had it.
there is a thread on this to just search for it.
but try that and see if that helps
Old Jan 28, 2008 | 05:39 PM
o really? hmmmm.. if royla purple can get rid of it..then royal purple is what ima be running...its a pretty respected oil aswell anway...
Old Jan 28, 2008 | 05:40 PM
so u think im safe to spray im doing nitrous outlet 100 dry ****
Old Jan 28, 2008 | 05:46 PM
i would do a compression check first.
Old Jan 28, 2008 | 05:51 PM
**** or shot?
Old Jan 28, 2008 | 05:52 PM
so piston slap can cause a loss of compression?
Old Jan 28, 2008 | 05:53 PM
it could. but its a really good thing to do before running nitrous on any motor, and you really want to do it with high milage engines
Old Jan 28, 2008 | 05:58 PM
ok man thanks for all your help
Old Jan 28, 2008 | 10:56 PM
Quickshift_C5's Avatar
I have a 99' FRC Vette that has had a problem similar to this from the day I bought it. I have been told by numerous people that the LS1 just sounds like that and not to worry about it, but I haven't been able to stop worrying about it since day one.
Mine is a very light ticking noise. It's like a baseball card in the spokes of a bicycle. The intesity of the ticking increases and falls with RPM. It's never got louder, it's never got quieter. I've owned the car over a year now, and it's done it the entire time. It dyno'd at 312rwhp(SAE) with only B&B Route 66 exhaust. I'm about to the point where I'm going to bring it to a local Chevy dealer and see what they think, I just don't know.
How does one come to a final decision of whether or not this is a HUGE problem without tearing down the entire motor to carefully inspect every single part?
Old Jan 28, 2008 | 10:57 PM
its normal
Old Jan 28, 2008 | 11:02 PM
Originally Posted by Disturbed Bird
its normal
Really?
What causes this noise?
Old Jan 29, 2008 | 12:13 AM
Apollo0526's Avatar
Lifter?? That what i thought mine was, and i just noticed it in the last month, but i'm doing heads and cam soon so i didn't worry bout it
