Sump plug Thread
Old Jan 29, 2008 | 02:21 PM
Ricky_GD's Avatar
Default Sump plug Thread
Hi, can anyone tell me what thread my sump plug will be? i have an LS1 engine in a cobra ( gd kit car) and want to hook up a oil temp sensor. so i plan to get an adapter to my m10*1 oil temp sender. its a 1999 fbody LS1 out of a camaro.
thanks in advance
Old Jan 29, 2008 | 02:47 PM
405HP_Z06's Avatar
thanks in advance
Are you talking about the oil pan drain plug? Wouldn't the best place to put the oil temp sensor be the stock location above the oil filter?
Old Jan 29, 2008 | 03:05 PM
Ricky_GD's Avatar
yer sorry english names may be diff, im after the thread size for oil drain plug.
i cant use the stock location as its being used as part of the oil cooling system.
Old Jan 29, 2008 | 04:23 PM
405HP_Z06's Avatar
It's M12 x 1.75. Most oil cooler adapter blocks have a port for the oil temp sensor, which one are you using?
